ran out of gas and now no start.
Old Jun 21, 2013 | 01:12 AM
evilemokid94's Avatar
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
Having an issue. Ran my car out of gas yesterday and had to push it into a parking lot. After I got it in the parking lot I put $25 worth of gas in it and let the pump prime and tried to start the car, no dice. Well I took off the line going go my fuel pump under the hood and turned the key on and my pump still wasn't pumping gas. Well I got it towed home. And tried blowing air through the line going to the tank and couldn't get any air to push through. So I though clogged fuel filter. So today I crawled under my car, got the rail fuel filter off and blew through the line using compressed air and got the line from the engine back to the filter cleaned out. But when I try to blow compressed air in the line going from the filter to the tank I can't get it to push through either. Now the way I have my car rigged for now is I have the stock in tank pump still in the tank, fuel filter on the rail, and a carb pressure fuelpump under the hood sucking fuel through the in tank pump and filter. Doss it sound like the sock is clogged or fell off? Should I be able to push pressurised air through the the like going to the tank?
Old Jun 21, 2013 | 02:16 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: ran out of gas and now no start.
Originally Posted by evilemokid94
I have the stock in tank pump still in the tank, and a carb fuel pump under the hood sucking fuel through the in tank pump .
That would be dead wrong for starters because in-tank pumps are not designed to sucked through .
Should I be able to push pressurised air through to the tank?
No
There is a one way valve on the in-tank pump to prevent the fuel pressure built up by the EFI pump bleeding off back to the tank so that should prevent air flowing to tank as well
Try sucking on the line instead
Old Jun 21, 2013 | 07:39 AM
Engine: L31 350
No
I know the setup isn't correct, it was a temp fix till I could yank the tank and put a peice of line in there to fix my issue. The check valve makes sense. I'll pick up a siphoned pump today and try pulling it through.... overall dont want yo drop that tank till I have my new rear done and all my founders parts in yet.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
db057
Apr 28, 2019 07:45 AM
fasteddi
Sep 10, 2015 09:32 AM
TBRays98
Sep 6, 2015 05:05 PM
RyanJB
Sep 2, 2015 01:27 PM
