crank - no start
Old Jun 27, 2013 | 05:21 PM
norcaltransam84's Avatar
crank - no start
84. Trans am rebuilt motor and trans carb 4bbl new battery starter is good getting fuel to carb compression is good car putts like it wants to start but won't catch timing is on point hei distributor electronic advance any advice or input on what else to check would be greatly appreciated
Old Jun 28, 2013 | 03:35 PM
smittyakalance's Avatar
Car: 1991 Z28
Engine: 383 Stroker with edelbrock heads
Axle/Gears: 4.10 Posi
Re: crank - no start
Check your spark plug wires, and then double check your spark plug wires
Old Jun 28, 2013 | 07:40 PM
I've checked double checked and triple checked everything ..... took out all pkugs pulled dist out reset the timing and plugged all wires back in still nothing just sounds like it wants to start but won't catch
Old Jun 28, 2013 | 09:42 PM
Car: 1991 Z28
If its cranking and not firing it's your timing when you pulled dist out its out of whack, can't go by timing mark if your balancer is old, take driver side valve cover off, get a 5/8 socket and breaker bar hand crank engine when second valve is at
The top it's top dead center and rotor will be pointing at #1
Old Jun 29, 2013 | 04:33 AM
New harmonic balancer cam'd roller rockers push rods lifters pistons everything in spec battery new plugs wires and now starter new still won't start ..... I'm f'n stumped idk what yhe hell yhe problem is .... it ran then just shut off
Old Jun 29, 2013 | 06:53 AM
Car: 1991 Z28
Check your fuses, and I changed all of that stuff too, and still had my
Timing off, it's never a bad Idea to take of four 3/8 bolts off the valve cover and reset tdc so you know you're positive
Old Jun 30, 2013 | 05:19 AM
Got tdc seems that cranking the old starter with the new batter killed my new battery even though it read 11.8v but I had ot tested and it was at 10% charge new dmm might be next but now it starts and runs but idle is back at 2k and if I back it down to 800 it won't start actually it won't start unless its at 2k this is starting to get on my nerves
Old Jun 30, 2013 | 09:08 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Vac leaks ?
What is your timing set at ?
What dizzy ?
To set the idle at 2K you are opening the butterflies, so if it won't start with the butterflies at the proper idle setting then you have a air / fuel problem.
Is carb (what carb ) jetted for engine ( has this carb been run on this engine before ? )
Old Jul 1, 2013 | 02:13 AM
No vac leaks stock dist wit msd cap rotor and coil hei 0deg tdc carb is 4bbl rochester stock and it ran on the car before
Old Jul 2, 2013 | 07:34 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Are the plugs wet or dry?
Wet = no or weak spark
Dry = no fuel
Old Jul 3, 2013 | 03:28 AM
The plugs are black and a little moist i was running rich I got it to run I got the distributor set and clamped down able to start and cut off no problem took it out for a test run and drove about 20 mins then the car started over heating I know the fan didn't kick on so I need to check the fan motor and relay went back to get the car after 5 hours of cooling down and now it won't start again tried turning the dist while cranking and nothing it'll catch but as soon as I get off the key and stop cranking it cuts out ..... ignition switch maybe ? But the ignition switch is also new i don't know of cranking too many times will kill it though .... seems like one problem gets fixed and another rises ......any ideas or help ?
bryan623
Mar 22, 2021 06:43 PM
Caspar
Jun 19, 2016 11:19 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
