Help...fuel pump ?
Old Jun 30, 2013 | 06:51 AM
MikeMN's Avatar
Car: 1988 Trans Am GTA and 1979 10th Anv
Help...fuel pump ?
I have a 1988 5.7 TPI trans am GTA, the car was running fine and a few minutes later I went to start it and it would hardly stay running, one thing I had noticed is that now I do not hear the fuel pump running at all but it will still start but I have to feather the gas pedal and when I rev it up it runs rough and miss firers and the exhaust smells rich with some black smoke, any ideas if this could be that I need a new fuel pump or...?
Old Jun 30, 2013 | 09:03 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Help...fuel pump ?
Originally Posted by MikeMN
any ideas
have you pulled the engine codes to see if anything amiss ?
the exhaust smells rich with some black smoke?
Running rich
Many possibilities
Bad CTS telling the computer engine is colder than what it is so it adds too much fuel ?
Leaking injectors maybe ?
Unlikely the pump is the problem if engine is rich
Have you done a fuel pressure test and a leak down test on the injectors.
Old Jul 1, 2013 | 04:39 PM
MikeMN's Avatar
Running rich
Many possibilities
I had a code for the MAF burn off relay and replaced it with no change in the way it runs, that is all I have done so far, the main thing that I have noticed is I do not hear the fuel pump come at all, I could always hear it come on before starting it and after it was running, Thank you for responding.
Old Jul 1, 2013 | 06:24 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Think about it.
If the pump wasn't running neither would the engine
Old Jul 1, 2013 | 06:46 PM
MikeMN's Avatar
Think about it.
I know, that's the weird thing about it.
Why do you think the pump is NOT making any noise but yet it will still runs half azz .......... ?
Old Jul 1, 2013 | 09:09 PM
BASSETT IROC 85's Avatar
Car: 1987 Camaro Sport Coupe
Engine: 355
Axle/Gears: 7.5 inch 342
Need to check fuel pressure with a gauge. Sounds like a bad fuel pressure regulator.
Old Jul 2, 2013 | 01:16 PM
TPeye's Avatar
Car: 1992 Camaro Z28
Engine: 350ci
I second the fuel pressure thought. There is a thin rubber diaphragm inside the fuel pressure regulator that can tear. Once torn, you can smell gas from the vacuum line that is connected to it. I attached a picture of what it looks like
Attached Thumbnails Help...fuel pump ?-chevy_camaro_1992_fuel_injection_pressure_regulator_oem_pr10.jpg
Old Sep 1, 2014 | 05:24 PM
MikeMN's Avatar
Re: Help...fuel pump ? " Update "
Update, I solved the problem.
It was the pick up coil and what ever the thing is called in the last pic was hitting the outer piece, car now runs great after 2 years sitting in the garage with a new distributor installed...
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Gunsbee
Sep 7, 2015 07:10 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
