vortec bolt pattern same as 87 and up?
Old Jun 30, 2013 | 11:41 PM
iroczjoe's Avatar
Car: 1987 iroc z
Engine: 305 tpi for now
Axle/Gears: 3:24
cant seem to find a straight answer. im working on another 87 iroc 305 700r4.
im doing a tpi to carb swap and someone told me you have to use vortec intakes for 87 heads because of the bolt pattern. im going to put on a set of vortec heads in the near future any way so i dont mid buying 1..............
Old Jul 1, 2013 | 03:52 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: vortec bolt pattern same as 87 and up?
Only have to look and compare the two intakes ; Not even close
Vortec head has only 4 bolts a side , reg SBC heads off all years have 6 bolts
And the intake ports are a completely different shape so even if the intake did bolt up , it wouldn't work
Old Jul 1, 2013 | 03:55 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
someone told me you have to use vortec intakes for 87 heads because of the bolt pattern. .
'87+ heads have a different bolt ANGLE to the earlier heads
If using any non Vortec SBC head you can make the other style intake work by just filing the intake bolt holes out to suit the different angle.
Exactly the same as the aftermarket intakes where one intake fits both style heads ; early and late .
MY87LT
Aftermarket Product Review
Jun 7, 2016 09:47 PM
Jorlain
Oct 8, 2015 01:57 AM
billybob6110
Sep 23, 2015 01:30 PM
Jlanz55
Sep 6, 2015 07:28 PM
UltRoadWarrior9
Sep 2, 2015 08:24 PM
