distributor problem
distributor problem
84 trans am 305HO 700r4 computer controlled carb and dist
Problem: I set timing everuthing is on point but when I reconnect the 4 pin connector after timing is set the car shuts off I was told tge diatributor is bad any ideas or suggestions on what to check to verify the distributor is bad or what else could be causing the problem and what else to check thanks in advance for any input given
Re: distributor problem
The dist is probably fine
Check the rotor, make sure the little contact end isn't pushed off to the side
92camaroJoe
Aug 13, 2015 06:07 AM
