Heater Core bypass question
Old Jul 8, 2013 | 07:05 AM
Apathy's Avatar
Car: 91 z28 Camaro
Hey guys,
Im leaking coolant on the passanger side so im assuming thats my heater core. Ive looked the hoses at the firewall and at the 2 ports on the engine as a temperary fix until I can get a new heater core. Now here my question:
Im still leaking coolant in the cab and on the rode when i go for a drive longer than 20 minutes. Is that coolant left over in the heater core that didnt come out when i blew on the hose? Or is this another problem that im not aware of?
PS I searched this issue on the forums and found many related problems but nothing on this problem after the temp fix.
Old Jul 8, 2013 | 10:03 AM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Axle/Gears: 9-bolt 3.27 & PBR
Re: Heater Core bypass question
You can get a plastic connector to connect the two hoses that go to the heater core. My local Napa store had a box of them behind the counter so I suspect it's not uncommon. Any coolant left in the core may leak depending on where the leak is but it won't be under pressure any more. Mine leaked all in one shot after the bypass so only one clean up.
Old Jul 8, 2013 | 11:01 AM
Apathy's Avatar
Car: 91 z28 Camaro
Yeah ive already looped the 2 hoses coming from the heater core. But im still leaking coolant.
Old Jul 8, 2013 | 01:29 PM
Base91's Avatar
Car: Base 91 'bird
Engine: 3.1 v6
Transmission: 4L60
Probably what's left in the core coming out as it sloshes around. A coreful of coolant will pretty much cover the whole passenger side floor pan. There's nowhere else for it to come from. Until you can remove it you'll just have to keep mopping. Maybe stuff towels under it.
Old Jul 8, 2013 | 06:49 PM
Apathy's Avatar
Car: 91 z28 Camaro
Alright mate thank you. I have a towel under the panel on the passenger side right now. Thanks for the help!
BumpaD82
Members Firebirds
31
Apr 4, 2019 10:36 AM
TheExaminer
Aug 26, 2015 04:59 PM
lakeffect2
Aug 23, 2015 08:44 AM
1985chevydude
Aug 22, 2015 05:36 AM
Cheibu70
Interior Parts Wanted
Aug 15, 2015 12:11 PM
