performer rpm fit under hood? whats stock intake height?
Old Jul 18, 2013 | 04:11 PM
demonband2000's Avatar
86 firebird trans am, now that it is running good time for something fun to
will a performer rpm fit under the hood?
And what is the stock intake height?
Presently I have a stock gm aluminum intake, not a hi Performance one just what came on a basic car in this era. Want a performer rpm and not a performer, since I have one available.
Old Jul 19, 2013 | 04:44 PM
mcrandrz's Avatar
Car: 1991 camaro rs
Engine: 3.1 - looking to upgrade to 3400 hy
Axle/Gears: Stock? Lol
It will not fit. My friend had his motor built with one and a holley 4 barrell. And the company slammed the hood and dented all the way through the hood. Now he runs it with no filter
Posted from Thirdgen.org App for Android
Old Jul 19, 2013 | 05:10 PM
Lewspike69's Avatar
Car: 1983 Camaro
Engine: 385 stoker
Axle/Gears: 10 bolt Torsen Posi 3.73 ratio
Re: performer rpm fit under hood? whats stock intake height?
I don't think so. My cowl just (>1/8 of inch clearance) clears my carb with that intake.
Old Jul 19, 2013 | 07:14 PM
GICATA's Avatar
Car: '83 WS6 T/A 65,000 miles
Engine: 5.0L vin H stock, 406SBC right now
Axle/Gears: Corp. 3.73
That's funny....I have had the Performer RPM with a Holley (and sometimes a Q-Jet) on my T/A for years with a 14X3 inch Moroso filter with a drop base...yes the top has a rub mark from the underside of the hood, but there is no damage to the hood and it certainly never bent or poked through the hood. Stock hood btw.
Old Jul 19, 2013 | 09:24 PM
I've got 2 1/4 inch of clearance from top of my air cleaner with the stock intake right now since
the filter is a low open element drop base, with a thin air cleaner.
Funny thing is I had a 82 z28 and the regular performer intake left no room. Had to use a stupid coal filter and it still hit. Possible the different eras had differing amounts?
How will the rpm work on a stock 350, with a q jet?
Old Sep 6, 2013 | 01:04 PM
DarrensCamaro's Avatar
Car: 1992 Camaro RS
Engine: 350 Carb'd
Transmission: 5 Speed
I am going through this same thing on my car with the same intake it will fit, its close but you need a drop base air cleaner. 1.75-2 inches.
Old Sep 6, 2013 | 01:20 PM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Yes it does,
You will need a dropped base air filter.
Moroso makes a nice 14" dropped base filter,
Also if you want to pick up some extra CFM use the K&N filter top. instead of the moroso solid top.
Old Sep 6, 2013 | 05:09 PM
426 Wedge's Avatar
Car: 86 WS6 TransAm
Engine: LG4 4BBL
Transmission: T5WC
Axle/Gears: 327
Call Edelbrock tech support. The can give you the measurements of their manifold vs. stock. I know, I went through this.
Old Sep 6, 2013 | 05:11 PM
426 Wedge's Avatar
Car: 86 WS6 TransAm
Engine: LG4 4BBL
Transmission: T5WC
Axle/Gears: 327
Btw I will never use another K&N or any other cotton type filter on any of my engines. Sure they allow more air in but at what cost.... they also let more dirt in to you engine too. You decide.
Old Sep 6, 2013 | 07:01 PM
I got it installed a while back. Fits great with a 3 inch filter drop base
Old Sep 8, 2013 | 02:06 PM
Car: 1992 Camaro RS
Engine: 350 Carb'd
which drop base air cleaner did you order? Any pictures that you can share?
Old Sep 9, 2013 | 09:24 PM
Cam455's Avatar
I've read that performer rpms fit and are a good upgrade. The air gap ones don't fit. This is info that I've read not practiced though
Old Sep 9, 2013 | 09:26 PM
Lewspike69's Avatar
Car: 1983 Camaro
Engine: 385 stoker
Well I don't know about the standard performer, I do know That my air gap rpm leaves little room with my cowl good as stated before. I didn't realize before that the refualr performer was the one the OP was talking about... Sorry!
Frozer!!!
Jan 19, 2024 04:55 PM
customblackbird
Aug 15, 2021 10:16 PM
Reddeath210
Oct 6, 2015 08:20 AM
TreDeClaw
Aug 14, 2015 06:58 PM
bryan623
Aug 10, 2015 11:33 AM
