Chevy High torque starter
Old Jul 18, 2013 | 11:54 PM
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
Hey everybody. I'm hoping someone could shed some light on how to wire a high torque starter. There are three terminals. The first two are obvious, they are both the same size I believe one is for battery the other runs to the motor itself. The only problem that I have is the spade terminal. The spade terminal on the original starter was a stud with a nut on top that the smallest wire slipped on, then the nut was threaded on. What I have now is just a spade with no stud or nut. How am I supposed to get the small wire on the spade terminal?
Old Jul 19, 2013 | 12:07 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Chevy High torque starter
http://www.radioshack.com/product/in...ductId=2103499
Cut the lug off the wire and crimp on a spade connector ?
Old Jul 19, 2013 | 12:12 AM
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
Yeah that's what I was thinking......
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
I was also wondering If i could take the solenoid off the old starter and put it on the high torque starter
Old Jul 20, 2013 | 01:13 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Would depend if it is exactly the same solenoid
Old Jul 23, 2013 | 03:25 AM
sotodn1's Avatar
Car: 1986 Iroc-Z
Engine: 5.7
Yeah, you are right. I ended up just cutting the tip of the wire and inserting and crimping a space terminal connector.
mhatfield 14
Oct 24, 2015 07:48 AM
5spdcamaro
Aug 28, 2015 02:12 AM
Dialed_In
Aug 20, 2015 01:45 PM
milk
Aug 10, 2015 06:26 PM
gwade12
Aug 8, 2015 08:17 AM
