88 iroc-z engine rebuild.
Old Jul 19, 2013 | 05:24 AM
Szpara31's Avatar
Car: 1988 IROC-Z
Engine: LB9
Transmission: M5
I'm new to the 3rd gen and have been reading a lot of posts on what parts to use for specific rebuilds. As I am new to third gen I am new to car performance as well. What I am asking is for guidance in rebuilding a stock 88 iroc-z 305 5-speed. I don't want to swap because I'm a father and in the military working with a blue collar income. Please help me with this gentleman.
Old Jul 19, 2013 | 06:29 AM
jas2730's Avatar
Car: 89 IROC Z/88 IROC Vert
Engine: 350c.i./305c.i.
Transmission: 700R4/T-56
Axle/Gears: 3.42/4.10
Re: 88 iroc-z engine rebuild.
What specific questions do you have about the rebuild? What Is the reason for the rebuild? Help us help you.
Old Jul 19, 2013 | 07:49 AM
Szpara31's Avatar
Car: 1988 IROC-Z
Engine: LB9
Transmission: M5
I'm rebuilding for performance, in a budget of 2500-3000. I really don't have time to do it myself so I will have to put it in the shop but I don't want to be screwed by guys that know the business when I don't.
Old Jul 19, 2013 | 07:51 AM
Szpara31's Avatar
Car: 1988 IROC-Z
Engine: LB9
Transmission: M5
For questions, I wanna know what parts I would get the most for rebuilding and why. I really want to learn everything I can about this vehicle.
Old Jul 19, 2013 | 08:24 AM
jas2730's Avatar
I know you said you don't want to swap engines but you should reconsider that. It's extremely tough to make power with a 305. You have a good budget to work with for an engine swap. Not so much if your trying to build a 305 for power or a engine build in general. I just built a 350 for my 89. My 2k budget quickly blew past 4k with me doing all the work myself.
Old Jul 19, 2013 | 08:29 AM
jas2730's Avatar
But to answer your question, heads, cam and intake are the areas were you should spend your money. The top end of these motors are very restricted. The were built for torque not horse power.
Old Jul 19, 2013 | 09:41 AM
DiabolicalRS's Avatar
Car: '90 Camaro
Engine: 305 tbi
Axle/Gears: 9 bolt posi 373
whee in nc are you stationed at? ive been seeing alot of third gen lately but no one ever really wants to talk or do anything fun
Old Jul 19, 2013 | 10:35 AM
Szpara31's Avatar
Car: 1988 IROC-Z
Engine: LB9
Transmission: M5
Stationed on camp lejeune. I am not wanting to do a swap because I've heard that the transmission I have would not do to well with a 350, and swapping a tranny and engine would be time and costly.
Old Jul 19, 2013 | 10:38 AM
jas2730's Avatar
It will handle a mild 350.
Old Jul 19, 2013 | 10:40 AM
jas2730's Avatar
Are you Against an ls1 t56 swap?
Old Jul 19, 2013 | 10:45 AM
Szpara31's Avatar
Car: 1988 IROC-Z
Engine: LB9
Transmission: M5
I'm not against anything as long as I get hp and it stays relatively cheap
Old Jul 20, 2013 | 01:00 PM
Szpara31's Avatar
Car: 1988 IROC-Z
Engine: LB9
Transmission: M5
So when it comes to heads cams and intake what's my best options?
Old Jul 20, 2013 | 01:27 PM
jas2730's Avatar
There's a million different options out there but with your budget that narrows it down. If I were on your budget a set of 113 vette heads are something I might look at. They can be had for around $500 for the pair and are a upgrade over your stock heads. Check out member MRBrisk. He has a pretty decent 305 setup in his 87 IROC. Intake, I'd try a Holley stealth ram to raise the rpm range and a cam to help it breath above 5000 rpm as well. Those pieces on a $3k budget should keep you under $2k leaving you some cash for labor If you buy the heads and intake used.
Old Jul 20, 2013 | 02:06 PM
jas2730's Avatar
Actually there's a set of 113's and a zz4 roller cam for sale in the classifieds right now for $500.
Steven 86IROC-Z
May 24, 2026 04:52 AM
backtothe80s
Sep 5, 2015 12:39 AM
StevenB L98/LS1
Aug 22, 2015 09:03 AM
PestilenceIV
Aug 20, 2015 02:33 AM
bradleydeanuhl
Aug 12, 2015 11:48 AM
