Harmonic Balancer and Flexplate Question
Car: 1985 Camaro Z28
Engine: Work In Progress
Transmission: 700R4/2200 stall/Shift Kit
Axle/Gears: 7.5 Richmond 3.73/Gov Loc Posi
In a few months I will be ordering this short block to build
http://www.summitracing.com/parts/hpe-sp04
and in the ad it says the balance is internal/external. Well whenever I go on summit it only shows harmonic balancers that are for sbc for internally balanced motors. So what harmonic balancer and flexplate would you guys recommend? I don't have the money for a super damper and this motor is going to be a street motor with a visit to the strip like 1-2 times a year. Will never go higher than 6000-6500 RPM
Re: Harmonic Balancer and Flexplate Question
The operative word is STOCK. Try not to get all hung up over "internal" and "external". Those words only confuse the issue with otherwise STOCK 1-pc rear-main-seal motors.
STOCK.
Don't outsmart yourself. It takes your STOCK damper and flex plate. New, good-quality replacement, is a great idea, particularly f you intend to stress it out a little bit; but STOCK balance is the key here. Nothing in the bottom end of that motor is ANYTHING BUT stock.
Given that, I'd suggest strongly resisting the impulse to do very much of
Remember, all it is, is a STOCK bottom end.
OE cast crankshaft
OE connecting rods
6000-6500 RPM
Thanks, this helped a lot but when I'm on summit they are still wanting to know if the engine is internally or externally balanced when choosing a flex plate for a sbc 1 piece and even though this harmonic balancer
http://www.summitracing.com/parts/su...make/chevrolet
is for an "internally balanced sbc" I'm assuming it will still work since it's titled OEM? Thanks for the reply
All SBCs are internally balanced, except for the 400.
86-up 305s and 350s have the rearmost bit of internal balance weight located on the flywheel or flex plate, instead of being part of the crank. This gives rise to endless confusion but doesn't change the basic fact that the engine is internally balanced. "Internal" and "external" DO NOT refer to side of the bolt split that the weight is on, even though some of the aftermarket crank mfrs and such, have thrown in the towel and mangle the terms as badly as typical street strokes do.
All dampers for 262.5, 265, 267, 283, 302, 305, 327, and 350, are for internal balance.
Thanks! I'll just buy an internal balanced damper and flex plate from summit. This helped a lot
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
No
Buy one for a 1 pce RMS engine
See post # 4 above
Summit add to the confusion by frequently listing 1 pce flexplates as both internal and external balance
See
http://www.summitracing.com/search/p...rder=Ascending
This one for example is correct for a 1 pce RMS engine
http://www.summitracing.com/parts/fc...make/chevrolet
and you can see it has the balance weight on it that makes some people wrongly call it external balance
See post # 4 above
See
Ok that makes sense. Yeah summit just emailed me saying to buy a harmonic balancer that is internal balanced but buy a flex plate for a 1 piece that is "external" balance. Thanks so much.
Transmission: 4L80E/4L80E
It is disappointing that Summit perpetuates the confusion with this "internal/external" stuff.
I also take exception to the use of the term "harmonic balancer". It isn't a "balancer", it's a "damper". Its purpose is not to balance harmonics, its purpose is to dampen harmonics.
Car: 82 Z28
Transmission: T400
Engine: Aluminum 615BBC
Axle/Gears: 4.11/4.30/4.56
on a side note:
most or all your aftermarket parts list for the 406/413/421/427/434/454 small blocks will be internal bal..
Car: 82 Z28
Transmission: T400
there are budget 383 stroker crankshafts based on 400 castings that are TRUE external balance and require the 400 style weighted flexplate and dampener
http://www.summitracing.com/parts/es...make/chevrolet
And just to really confuse people
ya I just sold a set up. fluid damper and flexplate for ext bal
for the 3.75 stroke 400 crank in the 350 block
stick with the intern bal parts.. lighter wt stuff
84z96L31vortec
Aug 20, 2017 12:16 AM
gixxer92
Sep 1, 2015 04:32 PM
84z96L31vortec
Aug 10, 2015 08:27 PM
