Washer Motor
Old Aug 7, 2013 | 04:57 PM
Kornis's Avatar
Car: 1986 IROC Z28 Camaro
Engine: 305 4BBL
Transmission: 5 speed Manual
Axle/Gears: 373 Limited Slip
Washer Motor
Can you just get a new washer motor and replace it? I also need to find a replacement for the window washer liquid container. It has sprung a leak. Figures it did not want to be left out since the Radiator, water pump, and head and sprung leaks in the last few months. Son over heated it bad enough to blow the radiator and radiator over flow tank to pieces. Looking back it was funny when he called me but oh the dollars to fix everything is not funny, but oh well, I did worse growing up since I street raced with my dad's GTO in the late 60's and early 70's. Man I wish I could get that car back.
Sorry, was living in the past for a sec there
Old Aug 17, 2013 | 06:02 PM
Kornis's Avatar
Engine: 305 4BBL
Re: Washer Motor
Problem fixed, used tank from U PULLIT JUNK Yard and new pump from store. All works now but the fluid barely comes out. I took a air compressor and cleared all line to be sure they were not clogged. Anyone else have this problem. It only squirts out about 8 inches up glass
Old Aug 19, 2013 | 04:51 AM
Kornis's Avatar
Engine: 305 4BBL
Re: Washer Motor
Figured out the low flow part out. Seems that the line that connects to the washer tank was not real tight. It fit ok but had to be allowing air to be sucked in as well. I put a piece of shrink tubing on the nipple and put the hose back on. All works too great now.
ZMWojnar
Brakes
May 12, 2019 10:43 PM
lt1z350
Sep 29, 2015 01:50 PM
MoJoe
Sep 15, 2015 12:50 AM
Randomtask2
Aug 26, 2015 03:34 PM
fonzie85
Aug 13, 2015 11:50 AM
