Ignition problems and no spark....Need help!
Old Aug 26, 2013 | 09:40 PM
ace322's Avatar
So my 1991 camaro z28 isn't getting any spark. I'm trying to test the resistance on the ignition module but don't know what the correct ohms should be for the resistance. Could anyone answer this question for me I already tried google? By the way it's the 5.0 TPI engine
Old Aug 26, 2013 | 10:08 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: Ignition problems and no spark....Need help!
I had to pull my ignition module off my distributor and get it checked at Autozone. It was bad. Replaced it and got my spark back.
Old Aug 26, 2013 | 11:29 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
I'm trying to test the resistance on the ignition module .
No spark testing .
http://easyautodiagnostics.com/gm_ic...n_module_1.php
read all 6 pages
Old Aug 27, 2013 | 08:03 AM
Kornis's Avatar
Car: 1986 IROC Z28 Camaro
Engine: 305 4BBL
Transmission: 5 speed Manual
Axle/Gears: 373 Limited Slip
\I had the same problem, all I did was disconnect the Tack and it started with no problems. Re-connected the tack, no spark
I am running now with out a TACK.
Old Aug 27, 2013 | 09:34 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
You found the cause of the problem but did not FIX the problem.
Did you inspect the tach wiring to repair the short circuit? & was the tach connect the correct side of the coil?
OP
The module in the distributor seldom goes bad, not saying that is not possible, but I would test the COIL first.
Then test and the high tension lead to the distributor.
inspect the distributor cap & rotor and all the spark plugs wires.
Rule out the obvious first.
Old Aug 27, 2013 | 09:39 AM
FRMULA88's Avatar
Car: 1988 Formula
http://www.autozone.com/autozone/rep...00c1528025f55c
how to test the HEI coil...
Old Aug 27, 2013 | 09:46 AM
FRMULA88's Avatar
Car: 1988 Formula
If you register with Autozone you have unlimited access to the repair guides
All these basic tests are in the Chiton's Manual for the 3rd gen... why not invest in the book if you plan to keep the car.
I had my Chilton's for over 20 years.. it is excellent reference material. they turn up on Ebay all the time and sometimes the OEM SHOP manuals as well.. since there is nothing OEM about by drivetrain I never bothered to invest in the shop manuals.
Old Aug 27, 2013 | 09:50 AM
FRMULA88's Avatar
Car: 1988 Formula
The easiest way to test a module on the car is to ensure that the wiring & pickup coil are OK. The module is essentially an amplifier with a built in analog to digital convertor.
Easy tests:
1. Test for power at the pink BAT terminal. You should have battery voltage w/ the key in the start and RUN positions.
2. Connect the ground side of your test lamp to the battery POSITIVE cable. Probe the TACH terminal on the dist. cap while a helper attempts to start the engine. The test lamp should blink repeatedly as the engine cranks. No blink= bad module or pickup coil. Further testing is required to pinpoint the problem. Blink but no spark = bad ignition coil.
3. Remove the cap & rotor. Remove the green & white leads from the module. Connect your ohmmeter to the green & white leads. You should have approx. 800-1500 ohms depending on the ambient temperature. Open circuit (infinite ohms) = bad pickup coil.
Wiggle the green & white leads as you test. Ohm reading should remain constant if the leads are good. If the reading varies as the leads are wiggled, the pickup coil is bad. You'll often find broken pickup coil leads this way.
4. DVOM (meter) still connected to green & white leads. Set your DVOM to AC VOLTS. Have a helper crank the engine as you watch the AC VOLTS reading. A good pickup coil will produce about 3V AC when cranking. Less than approx. 2V AC indicates a bad pickup coil.
Read more: http://forums.carcraft.com/70/661769...#ixzz2dBHjDNGV
Old Aug 27, 2013 | 09:52 AM
FRMULA88's Avatar
Car: 1988 Formula
If you have to remove or replace the module be sure to clean the mounting base and install new heat sink compound.
A new module should come with the compound in small applicator tube.
Infested
May 22, 2018 11:56 PM
mddaniel
Sep 8, 2015 05:16 PM
Bryan F
Aug 27, 2015 07:28 AM
Bryan F
Aug 18, 2015 02:28 PM
