Help with Valve Seals on a 1989 Iroc TPI
Old Jun 9, 2013 | 03:57 PM
perfectcircle75's Avatar
Hey guys, I have a 1989 TPI 305 iroc that i decided to put some valve seals in. That year has a service bulletein per GM That has an updated kit. The seals i removed were the rubber type with a band around them in the first picture. The kit i received from gm were metal ones with rubber top for the intake (pic 2)which had to be pressed on to go in place and white plastic ones for the exhaust that just slid down on the head. It also came with all the o rings. Im just not sure if this is right and after a few hours of searching on here i cant find a postive answer. Thanks ahead of time
Attached Thumbnails Help with Valve Seals on a 1989 Iroc TPI-valve.jpg   Help with Valve Seals on a 1989 Iroc TPI-new-valve-seals.jpg
Old Jun 9, 2013 | 06:42 PM
fireturd350's Avatar
Car: '90 Formula 350
Engine: 383 SBC
Transmission: ProBuilt S/S 700-R4 & ACT 9" Stall
Axle/Gears: 10 bolt 3.23
Re: Help with Valve Seals on a 1989 Iroc TPI
I've never used the metal ones. When I changed the ones on my 3800 series daily driver they were like the first ones with the metal band. They were included in my Fel-Pro Kit.
The ones on the exhaust do they at least fit good around the valve stems?
Another thing you could would be go to the local parts store and pick up some Fel-Pro ones and see if they fit tight. The $10 or whatever for them would be well worth it instead of having to tear it back down again.
Old Jun 9, 2013 | 07:47 PM
yeah the exhaust ones were really snug around the valve but they just basically sit on the head where as the intake ones pushed down fairly easily then had to be pressed on to the head. if that makes sense
Old Jun 10, 2013 | 02:22 PM
Jim85IROC's Avatar
Car: 85 IROC-Z / 88 GTA
Axle/Gears: 3.42 / ?
The metal ones are a more modern style. I installed those on my LS3 heads when I replaced the valve springs. Either style should work just fine as long as they're installed properly. I like the metal ones because it's easier to tell when they're fully seated.
Old Aug 13, 2013 | 04:23 PM
pjp209's Avatar
Car: Gone
How do you put
Old Aug 13, 2013 | 04:52 PM
Engine: 383 SBC
Originally Posted by pjp209
How do you put
Old Aug 13, 2013 | 04:57 PM
pjp209's Avatar
Car: Gone
Originally Posted by fireturd350
how to put these on
Old Aug 13, 2013 | 05:01 PM
Engine: 383 SBC
I've never used the white plastic ones before, but I would assume they should install the same as the intake side. Are they fitting too loose or something?
Old Aug 13, 2013 | 05:04 PM
pjp209's Avatar
Car: Gone
Not loose. when I took off the spring no seal was under it just that metal spacer for the spring.
Old Aug 13, 2013 | 10:58 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Transmission: TH700R4
how to put these on
Those opaque, white seals just fit over the valve stems and inside the springs under the retainers. They're really not "positive" seals which install onto the valve guide. They just keep oil from splashing onto the valve stems.
Most people call them, "umbrella" seals.
Old Aug 13, 2013 | 11:02 PM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
There should have been at least an umbrella seal and an o-ring in the second groove down on the valve stem.
Old Aug 13, 2013 | 11:58 PM
pjp209's Avatar
Car: Gone
There was one o ring no umbrella. So I just slip the seal over the valve?
Old Aug 14, 2013 | 08:58 AM
paulo57509's Avatar
Car: '87 IROC
Engine: LB9
Yes. But don't reuse the old o-ring. Use a new one. Some seal kits come with a small mylar tube that slips over the valve stem to protect the seals while installing them over the end of the stems.
  • Position the mylar tube on the valve stem.
  • Install the umbrella onto the valve stem.
  • Remove the mylar tube.
  • Position the spring shim (if there is one) on the head.
  • Position the spring, cap and retainer.
  • Compress the spring.
  • Install the o-ring on the valve stem while the spring is compressed. Don't let the retainer slide past the o-ring once it's installed. It'll get damaged.
  • Position the keepers and release the spring.
Old Aug 14, 2013 | 09:50 AM
Nathanl91's Avatar
Car: 88 sport coupe
Engine: L03 305
Fel pro kit was positive type and o ring for intake and unbrella and Oring for exhaust, works good so far just did mine last weekend
Old Aug 14, 2013 | 12:08 PM
pjp209's Avatar
Car: Gone
How far do I slide the white umbrella onto the stem? Like this pic here that's the only way it will fit. Is it the rite way? Thanks
Old Aug 14, 2013 | 05:30 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
It's ok. On the exhaust side, the seal can even go up and down with the valve. It just keeps the oil from splashing on the stem.
Old Aug 14, 2013 | 05:37 PM
pjp209's Avatar
Car: Gone
Ok ill finish up tomorrow. Thank you
Old Aug 27, 2013 | 10:08 AM
pjp209's Avatar
Car: Gone
Got done a few days ago just been busy. Thank you all for the help
Wade787b
Sep 29, 2015 01:15 PM
kyleb24
Aug 15, 2015 08:24 AM
BewleyBizzIROC
Aug 14, 2015 02:52 AM
Sanjay
Aug 12, 2015 03:41 PM
mustangman65_79
Aug 11, 2015 03:17 PM
