Vortec head cam selection
Old Aug 27, 2013 | 05:17 AM
benji84cam's Avatar
Car: 84' camaro SC
Engine: 2.8l carb
I know it's been repeated over and over but what am I expecting lift wise on l31 roller heads running ls6 valvetrain (springs, retainers, keepers) what would be the best rocker arms? Sorry for the repeated question but its my first build so I wanna be safe but have utilize as much lift as possible. I've heard mixed things from .532 to .507 and even people saying close to .600.
Old Aug 27, 2013 | 06:23 AM
novaderrik's Avatar
Car: 86 Camaro
Engine: 355- hopefully a 5.3 this summer
Re: Vortec head cam selection
i can tell you from experience that unported vortecs are a blast with the HOT cam that has .525 lift... just make sure to add screw in studs to your shopping list...
Old Aug 27, 2013 | 06:52 AM
midias's Avatar
Car: 1984 Trans Am L69
Axle/Gears: 3.42 10 Bolt Posi
What compression are you going to run?
Roller or tappet cam?
Also if you get them machined for screw in studs I would add 1.6 exhaust valves.
Old Aug 27, 2013 | 08:43 AM
Gsoleski's Avatar
Car: 1984 Z28
Engine: Vortec 350, hotcam
If you go with 1.6 rockers the pushrod holes have to be enlarged as well. If you want to go roller check out the vortec hot cam builds. I just finished up my 350 with that combo and it's very fun!
Frozer!!!
Jan 19, 2024 04:55 PM
84z96L31vortec
Aug 20, 2017 12:16 AM
Tinbender59
Mar 17, 2017 10:50 AM
bamaboy0323
Sep 3, 2015 06:07 AM
84z96L31vortec
Aug 10, 2015 08:27 PM
