Hydraulic Clutch Slave Assembly question
Old Aug 27, 2013 | 02:12 PM
806camaro's Avatar
Car: 1990 IROC
Ok, I can't not get the U-Bolt out of the firewall. I took off 2 nuts against the fire wall from the inside. The u-bolt will not budge at, I'm even done some heavy tapping on it, nothing. Am I missing something else to take it off?
Old Aug 28, 2013 | 03:40 AM
green92's Avatar
Car: 92 RS
Axle/Gears: 3.08
Re: Hydraulic Clutch Slave Assembly question
Exactly what are you trying to take off ? The slave assembly is on the side of the motor/tranny to push the fork. The master cylinder is that what you're talking about? It's mounted beside the brake master cylinder on the firewall. I'd have to look at my car when I get off work to possibly help ya out.
Old Aug 28, 2013 | 07:43 PM
806camaro's Avatar
Car: 1990 IROC
I'm replacing the whole assembly. But yes, right now working on getting the master cylinder out of the firewall. It won't budge at all.
Old Aug 28, 2013 | 07:59 PM
green92's Avatar
Car: 92 RS
Axle/Gears: 3.08
Ok. I haven't looked at mine but I've never had to change it. So the rod running to the pedal have you looked at it. I'm not sure but it seems as if there should be something holding on there as well.
Old Aug 29, 2013 | 06:35 AM
stealtht/a's Avatar
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
I think there are some locking washer like things as well as the nuts on the cabin side. If you have those off, the u bolt can be difficult to get out. It has to come out evenly or the threads get stuck on the holes. Use a block on both ends of the u and tap w hammer. It's also possible to be rusted in place.
Old Sep 3, 2013 | 03:29 PM
806camaro's Avatar
Car: 1990 IROC
Well I finally managed to get the U-Bolt out last night. Stuck a flat head screwdriver between the master cylinder and firewall and with some wiggling and cussing, half a pack of reds the bolt came out.
1992 Trans Am
May 10, 2023 07:19 PM
Cleotiz
Jan 6, 2018 08:56 PM
redmaroz
Aug 16, 2015 11:40 PM
rsrmoore
Aug 7, 2015 08:44 PM
