New Hypertech Cool Fan Switch turn on way too early.
Old Aug 31, 2013 | 10:17 PM
nakota2k's Avatar
Car: 1989 Iroc-Z 350
Installed a 180 thermostat and the hypertech 200 on 185 off cool fan switch. Both fans turn on well before 160 and run constantly. Is the switch faulty, how can I remedy this? Does the temp gauge on my dash take its readings from the cool fan switch or a different sensor?
Old Aug 31, 2013 | 11:27 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: New Hypertech Cool Fan Switch turn on way too early.
Quite likely ,
Put it in a pot of hot water and using a thermometer ,check what temp it closes at, need a DVM
A seperate 1 wire sensor in the head
Old Sep 3, 2013 | 07:47 PM
nakota2k's Avatar
Thanks, how bad is it to have the fans pretty much running constantly? In this Arizona heat its keeping the engine about 160 which I know is below regular operating temp. My thermostat is a 180.
Old Sep 3, 2013 | 08:23 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
its keeping the engine about 160 which I know is below regular operating temp. .
Fan motors will burn out early and engine won't get up to operating temp to burn off the condensation so you will get sludge build up in the engine.
Not to mention usually worse fuel economy
Old Sep 3, 2013 | 08:48 PM
nakota2k's Avatar
Not what I wanted to hear lol. Its really a love hate relationship with this car. I'll pull and test it and if not order a new one from JET instead.
Old Sep 4, 2013 | 12:44 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
How much you paying for them ?
Consider this one.
http://www.racerpartswholesale.com/p...n_Accessories2
May need a 1/2" to 3/8" NPT reducer if your heads have the old style big hole
Available from any parts or plumbing supply place , maybe even hardware shop
See
http://www.summitracing.com/parts/rnb-43104/overview/
Old Sep 4, 2013 | 01:30 AM
nakota2k's Avatar
Consider this one.
See
I already ordered early today. 42 bucks. Thanks for the info though, I didn't see that one.
http://www.summitracing.com/parts/jet-60600/overview/
Old Sep 5, 2013 | 01:14 AM
Ron U.S.M.C.'s Avatar
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Also call around and have a shop point a infrared laser temp gun at the sender in the head and compare that to your gage. If you don't know where that is just have him point it at the thermostat housing. They will usually just do it for free.
RazorN8
Jan 7, 2022 11:44 AM
NBrehm
Aug 25, 2015 11:49 PM
Bryan F
Aug 18, 2015 02:28 PM
Fronzizzle
Aug 9, 2015 01:15 PM
Leggman1
Aug 6, 2015 04:15 AM
