center cylinders lean
Old Sep 2, 2013 | 04:37 PM
FtrSpeedy's Avatar
Car: 14 scion tc/91 camaro rs
Engine: 2.5/ 360 pooch
Transmission: 6spd man/th350
Axle/Gears: na/2.73
Any ideas, center cylinders both sides pretty lean, 4 corners slightly rich. Im stumped
Old Sep 3, 2013 | 07:57 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Re: center cylinders lean
Fuel distribution; Remember it's a single carb with a common plenum manifold and the intake runners are different lengths.
Pretty typical, however the cylinders with the longest intake runners the plugs will usually read leaner, 1 2 7 8 that does not mean it's wrong.
what kind of carb and jetting? what engine speed? short drive or? with a lumpy cam fuel distribution will be less than ideal until engine speed picks up.. are you checking plugs after idling only?
Old Sep 3, 2013 | 11:53 AM
FtrSpeedy's Avatar
Axle/Gears: na/2.73
Edelbrock 1411 750cfm weighted secondary butterfly removed. 110 pri, 107 sec, 75/47 rod 8in spring. Cruise speed 2000-2500 20mile round trip with occasional playin, checked plugs after couple hundred miles. 224 duration 112lsa. Intake holley street dominator
Old Sep 3, 2013 | 01:55 PM
FRMULA88's Avatar
Car: 1988 Formula
I know little about edelbrock carbs but if the jetting is like holley then
holy smokes you have way too much jetting for a small cu in. "street engine"/
Case in point on my 950 cfm QFT double pumper had 86 primaries and 94 secondaries with a primary power valve. Otherwise 94s all around with no power valve and this was with E85 fuel making 680 HP.
jetting with gas carb would be less. also you want smaller jets on the primary side... not other way around.
110s and 107s those are alchohol sized jets...
Old Sep 3, 2013 | 02:23 PM
JaBoT's Avatar
The jetting on edelbrocks have no relation to holley jetting. That is not big for edelbrocks.
Old Sep 4, 2013 | 10:14 AM
FRMULA88's Avatar
Car: 1988 Formula
I have no experience with Edelbrock carbs, however if larger # means larger jet orifice then it seems odd to use larger primary jets and smaller secondaries, typically you do the opposite.. (smaller primaries)
if the metering rods act as the "power valve" does on a Holley you are
dumping more fuel on the primary side, before the secondaries open.
you also have the accelerating pump squirting fuel when you mash the gas. (dumping even more fuel on the primary side)
I would try leaning out the primary jets a bit and see if that improves the fuel distribution.
Old Sep 4, 2013 | 11:16 AM
JaBoT's Avatar
Once again edelbrock jets have no... I repeat no relation to holley jetting.
It comes with 113 in the primary and 101 in the secondary from the factory for a reason.
The primary jet always has a part of the multi step metering rod in it.
Old Sep 4, 2013 | 12:00 PM
FtrSpeedy's Avatar
Axle/Gears: na/2.73
Ya the rod goes into the pri jet, so. 110 hole with a .057 rod inside.
Old Sep 9, 2013 | 08:43 PM
FtrSpeedy's Avatar
Axle/Gears: na/2.73
Ok well i believe i got it figured out, just waiting to get car back then ill check my theory. Thanks for your help.
manualbrakes.com
Brakes
63
Apr 9, 2024 11:55 AM
PurelyPMD
May 5, 2016 04:57 PM
IROCZDAVE (88-L98)
Exterior Parts for Sale
Sep 22, 2015 08:28 PM
dimented24x7
Sep 17, 2015 06:58 AM
IROCZDAVE (88-L98)
Sep 6, 2015 06:23 AM
