90 RS with 350
Old Sep 5, 2013 | 08:17 PM
Joshua615's Avatar
90 RS with 350
I wasn't sure where to post this but im going to buy a car tomorrow it is a 90 rs 5-speed with a 350 in it, obviously not the original engine. The car has 170,700miles on the body and i think i can get it for $1550. Is this a good deal?
Old Sep 5, 2013 | 09:21 PM
cosmick's Avatar
Car: '86 Camaro, '94 Camaro, 3 others
Engine: LG4 ->L29, L32->LR4, L36, LG4, L31
Transmission: 700R-4, T5WC, 4L80E, SM465, 4L60E
Axle/Gears: 3.42, 3.23, WTB/WTT 2.93
Re: 90 RS with 350
Seems fair if it hasn't ever been crashed, and if all the important parts are there.
Old Sep 6, 2013 | 03:28 AM
C-Titan's Avatar
Car: 91 Z-28
Engine: 360TPI
Transmission: PA Racing 700r4
Axle/Gears: 3:73
Re: 90 RS with 350
Don't believe that it's a 350 unless they can prove it... Happens allllll the time
Old Sep 6, 2013 | 07:40 AM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 90 RS with 350
Only way to confirm is from the engine casting # on the rear of the block.
Depending on the engine year , the casting # may be on the other side from that shown in the pic blow
Also ask if they changed the chip in the computer to a 350 one and the other items needed for a 350 swap
Old Sep 6, 2013 | 11:41 AM
Joshua615's Avatar
Re: 90 RS with 350
Would I be able to check there and just look it up on my phone?
Old Sep 6, 2013 | 02:57 PM
five7kid's Avatar
Transmission: 4L80E/4L80E
Re: 90 RS with 350
You should be able to. Getting your face down there to actually see the numbers is usually the hardest part.
Many blocks had the last 3 digits of the casting number cast into the side of the block in fairly large digits. It's usually easier to see those than it is to see the full number on the back of the block. You'll probably have to get under the car, though.
Bubbajones_ya
Jul 6, 2024 08:32 PM
TX-SleeperC5
Feb 24, 2016 01:34 PM
FormulasOnly
Sep 10, 2015 09:07 PM
FtrSpeedy
Sep 7, 2015 12:11 PM
Formula_88AE
Sep 3, 2015 01:47 PM
