To switch to carb?
Old Sep 16, 2013 | 12:18 PM
87IROCZCamro's Avatar
Car: Chevrolet Camaro IROC-Z,96 Vette
Engine: 350 5.7 Liter
Transmission: 700r
To switch to carb?
I have a 383 in my car that is still fuel injected with a stealth ram intake. I have been unable to get a tune for my car the last couple years and I havent raced it in a longer time. Im thinking about switching it over to carb so I can tune it manually and not have to worry about electronics. Yay or nay? Let me here you opinions.
Old Sep 17, 2013 | 09:06 AM
JaBoT's Avatar
Re: To switch to carb?
Unfortunately this is a big problem with these cars now. Nobody wants to or knows how to tune the ecu's, Unless you can do it yourself there isn't many options. There are a couple guys who can do a "custom" mail order chip if you give them your combo, but it's still never right. There are a few guys on here also that know how to. Maybe someone lives near you.
I would recommend either going with an aftermarket ecu like a fast and have a local shop tune it or switch over to a carb.
Old Sep 17, 2013 | 09:52 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
Who is doing the tune? The problem with the stock ECM is you can't tune it on the fly, you will need a flash burner & WIN ADL or other software to interface with the ECU.
You are local to me
did you Try Speed Inc. in Schaumburg?
or
ASSC (LRS Performance) in Lake Villa
Personally I really like working with Larry at LRS.
Otherwise why not just get an aftermarket system?
You only need the ECM and harness, most all of the EFI kits use GM sensors so it is plug & play.
There are options & advantages to keep the EFI and modify it versus switching to carb.
Old Sep 17, 2013 | 09:58 AM
FRMULA88's Avatar
Car: 1988 Formula
for example...
http://bigstuff3.com/wp-content/them...f/gen3sefi.pdf
This is a new ecm and harness that is compatible with your existing EFI sensors.
plus some major upgrades... Wide band O2s, data capture etc.
A shop like LRS can install and tune this on your car on their chassis dyno.
Old Sep 18, 2013 | 09:33 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Stay EFI and find someone who knows what they are doing.
Highly recommend you talk to this guy
http://scotthansen.net/
He will work with you to fine tune if you send datalogs
He did a custom tune for me a while back based on the specs I gave him and going by the datalog it is very close on his initial tune.
Old Sep 19, 2013 | 07:01 AM
FRMULA88's Avatar
Car: 1988 Formula
"cam with less than 224 degrees of duration @ .050 is possible with TPI.
For cams larger than 224 @ .050 will work with the speed density type 7730 ECM, but a different intake designed with shorter runners should be used.
This site will share with you what thousands of dollars has taught me.'
Old Sep 19, 2013 | 05:45 PM
Transmission: 700r
You are local to me
or
Speed Inc said no to me couple months ago. I will try LRS performance. Anyone hear of them and/or reputable?
MustangBeater20
Oct 29, 2022 09:20 PM
MustangBeater20
Carburetors
Aug 21, 2015 02:42 PM
stalkier
Aug 21, 2015 01:54 AM
Dialed_In
Aug 20, 2015 01:45 PM
86IROC112
Aug 17, 2015 02:00 PM
