car running rich
Old Sep 20, 2013 | 03:29 PM
lazey8's Avatar
Car: 1989 Trans am
Engine: LB9
Transmission: auto
Axle/Gears: 2.75
car running rich
Hi guys I have a 89 trans am with the 305 tpi my car has been running really rich. sometimes it is really hard to get it started after driving it for a little while. to get it started sometimes I have to hold down the throttle to clear the engines fuel out. after i get it started some times it will not stay running. today I reaplaced the o2 sensor but it still runs rich. the maf sensor looks new, what else could be causing this??
Old Sep 21, 2013 | 09:34 AM
mcquigg's Avatar
Car: 85 T/A
Axle/Gears: BW Limited Slip 3.27 w/disc brakes
Re: car running rich
Is your your car tpi? If it is then its more likely leaking injectors, give southbay fuel injectors a call.
Old Sep 21, 2013 | 02:00 PM
lazey8's Avatar
Car: 1989 Trans am
Engine: LB9
Transmission: auto
Axle/Gears: 2.75
ok thanks I will look at the injectors as soon as I get a chance, what size injectors should I use ?
Old Sep 21, 2013 | 03:43 PM
mcquigg's Avatar
Car: 85 T/A
305 will use #19 and the 350 will use #23 injectors.
Old Sep 25, 2013 | 03:06 PM
lazey8's Avatar
Car: 1989 Trans am
Engine: LB9
Transmission: auto
Axle/Gears: 2.75
I pulled the spark plugs and two of them looked like this
Attached Thumbnails car running rich-1378837_10201426483776877_1555578205_n.jpg
Old Sep 25, 2013 | 04:14 PM
Jonesyfxr's Avatar
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Make sure you don't have a plug wire grounding out on the left/ drivers side bank.
MustangBeater20
Oct 29, 2022 09:20 PM
Azrael91966669
25
Jun 20, 2017 04:04 AM
kyleb24
Aug 15, 2015 08:24 AM
squiggy2
Aug 9, 2015 09:30 PM
Kaweh
Aug 9, 2015 02:54 PM
