87 IROC-Z Won't Start
Old Sep 23, 2013 | 08:44 PM
Dippy99's Avatar
I was doing some research on a problem i'm having with my car when I ran across this site, I must say I love it. So I am new to this site. I have an 87 IROC-Z with a 5.7 TPI that is all stock except for K&N air filters and a cat back exhaust system. My problem is I got the car out of storage for the year 2 weeks ago. It was very hard to start but I eventually got it running and it idled fine after about 15 min. I took car out for a drive and had to feather the throttle to get it above 3,000 RPM above that I could hold it to the floor without any backfires, goughs, etc but it felt like it didn't have any power and was falling on it's face. I parked car for the night and the next day started it back up and let it idle for about 30 min, when I got into the car and put it into gear (automatic) it died and I have not been able to get it running since. I checked for fuel pressure in the rail and it didn't have any. I jumped the fuel pump and it runs, but I don't have any voltage in connector above rear axle, but I do have .3 volts when I crank engine over (Gray Wire). I also don't have any voltage at fuel pump relay, I didn't check voltage at relay while cranking engine over. I looked around and didn't see any broken wires or anything anywhere. I'm wondering if there is another fuse somewhere that controls the fuel pump or if I might have a problem with my computer?? Any help would be greatly appreciated!!!
Old Sep 23, 2013 | 08:58 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: 87 IROC-Z Won't Start
Originally Posted by Dippy99
got the car out of storage for the year 2 weeks ago. It was very hard to start but I eventually got it running and it idled fine after about 15 min. I took car out for a drive and had to feather the throttle to get it above 3,000 RPM above that I could hold it to the floor without any backfires, goughs, etc but it felt like it didn't have any power and was falling on it's face..
Did you put fresh gas in it , it goes "off' in storage
Old Sep 23, 2013 | 09:00 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
On which wire?
At the relay you have a power wire for the pump and a control wire for the pump relay
The control wire only has power for 2 sec when key 1st turned on or when the engine is running
the power wire is hot all the time, even with the key off
The power wire has a fuse under the hood
see
https://www.thirdgen.org/forums/post...165-post2.html
https://www.thirdgen.org/forums/post...547-post4.html
https://www.thirdgen.org/forums/elec...mp-inline.html
Old Oct 2, 2013 | 10:16 AM
LT2803's Avatar
Car: 1987 Camaro LT
Engine: 5.0L Carburated
Axle/Gears: Stock
Hey guys I am having a similar problem with an 87 Z-28 with the 5.0 TPI. I cant get spark. No power to the coil. The car hasn't ran in over 5 years I am working on it for a friend. Had to put a transmission in it and do some motor work since it was seized. I know that the fuel pump is bad because I have power to it but it wont run so that I know is bad. I want to know what it could be that is causing no power to go to the coil because I am at my wits end with this thing.
Old Oct 2, 2013 | 06:41 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Originally Posted by LT2803
I cant get spark. No power to the coil. .
check the wire from Ign switch to coil
Old Oct 3, 2013 | 12:17 AM
LT2803's Avatar
Car: 1987 Camaro LT
Axle/Gears: Stock
vetteoz I have checked all wires coming into the coil with the key on, with the engine cranking and with the key off and have no power at all.
Derick15
Sep 17, 2016 05:28 PM
Orr89RocZ
Apr 25, 2016 08:28 AM
Brcharrelson
Aug 26, 2015 07:47 PM
StevenB L98/LS1
Aug 22, 2015 09:03 AM
justin57
Aug 20, 2015 07:05 PM
