running plug wires under the manifolds.
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
What wires do you guys get when you run your wires under the exhaust manifolds? And how easy are they to route?
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
Re: running plug wires under the manifolds.
I ordered the Taylor wires from Summit. I'd have to look up the part number. Standby....
Taylor 51007 in black. Two straight boots for 2and 4, the rest 90*.
Car: 86 IROC
Engine: 5.0 TPI
Transmission: 700-R-4
Axle/Gears: 2.73 open
since I insisted on a set made for the large cap HEI (mines a 86,last year for the coil in cap HEI) I had to buy two sets from NAPA to get the wires I need. if your car still has the wire looms on the block its a cinch. as per the FSM the two straight wires go on cyls #6&8. all others are 90s
Engine: L31 350
Mines not a factory motor son I don't have the wire loom holders in just wanting them under the manifolds for look. I ordered a set for a 75 vette for length so hope I can.
1992 Trans Am
May 10, 2023 07:19 PM
Zachattack0925
Aug 12, 2015 09:54 PM
Zachattack0925
Aug 12, 2015 09:52 PM
