Tach not working. White wire from coil cut???
Old Sep 25, 2013 | 11:33 PM
servo2055chevy's Avatar
Car: 1988 Camaro Base model
Engine: 305 LO3 5.0L V8 TBI
Axle/Gears: 10Bolt Rear, Not sure the gearing
Ok long story short. I bought a 92 camaro RS 305 tbi like 6 months ago. The tach never worked. The guy said it was a bad cluster. Well I tried multiple clusters and it was a no go. Still never worked. I notice often at idle that the needle will slightly move like a poor connection. Tonight I got curious and checked out my distributer and coil. I saw a white wire that had a 2 wire connector coming from the coil. It went 3 inches then was wrapped in electrical tape and I uncovered a butt connector. Well I gave a little tug on the rigged "unit" and the white wire seperated from the rest going toward the firewall. There's also an in-line single wire connector headed toward the fire wall. I'm going to patch up the wire but what do I do if that doesn't fix my issue??
Old Sep 26, 2013 | 08:40 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Re: Tach not working. White wire from coil cut???
Fix this connection first and see what happens. This will determine the next step if necessary.
Old Sep 26, 2013 | 10:28 AM
Tach still doesn't work. I get power to the wire from the coil. No tach though. What's next? There's a little grey in line connector too? I cleaned the terminals and tried. No good
Old Sep 26, 2013 | 10:34 AM
Maybe my ignition coil is bad. Not sending enough voltage to the cluster? With the car running I was able to twist the wires together by hand to test the tach, I wasn't even getting a shock or anything?
Jeremys87
Jul 14, 2022 09:08 PM
stalkier
Aug 13, 2015 12:59 PM
mx127
Aug 10, 2015 08:13 AM
stalkier
Aug 7, 2015 04:49 AM
