No spark
Old Sep 28, 2013 | 07:06 PM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Transmission: Built TH350 with 3200 stall
Axle/Gears: 4th gen, 4.10
No spark
Hey guys,
Here's my latest dilemma. After I finally nailed down my timing and got the right jetting. I have another issue.
The car was starting and running pretty good each time I started it this week, however yesterday it wouldn't start. It was turning over fine and had good fuel pressure but no spark. Timing gun didn't light up as it was turning so I pulled number one plug and turned it over and it didn't spark either. I checked for voltage at the wire going into the distributor and got 11.88 volts.
this had had happened a few weeks ago causing me to swap out two distributors and eventually buy a brand new one.
I'm confused, I have voltage and all new distributor, cap and rotor but power isn't getting to the plugs.
Any ideas on what I can try here?
Car is a recently rebuilt, carbureted 350 with TBI wiring.
thanks
Old Sep 28, 2013 | 07:46 PM
antares57's Avatar
Car: 91 Firebird/88 Firebird/91 Formula
Engine: V6 3.1/V8 5.0/V8 5.0
Transmission: 4L60/700R4/4L60
Axle/Gears: 3.23/2.73/2.73
Re: No spark
Have you had the ignition control module checked or replaced. Mine was cranking but no spark. Autozone checks them for free. Good luck.
Old Sep 28, 2013 | 08:20 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: No spark
Originally Posted by patricklav
I'm confused, I have voltage but power isn't getting to the plugs.
Checked the coil
Plenty of online diagnostics available
http://www.speedyjim.net/htm/spark.htm
http://www.clarks-garage.com/shop-manual/ign-04.htm
http://www.aa1car.com/library/no_spark.htm
I have all new distributor, cap and rotor
Means little this days with el cheapo parts made off shore
Old Sep 29, 2013 | 09:55 AM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Re: No spark
Interesting, the first time I tested the spark at the plug it was not touching anything metal and it didn't spark or light the timing light. Afterward I put the spark plug on grounded metal and it did spark and the timing light lit up. Looks like somehow my engine block isn't grounded properly because the plug will fire when laying on grounded metal but not inside the block. Im going to check my ground wire to see what the problem is.
I currently have a ground wire from the negative battery terminal to the frame, and another wire to the block by the starter. I have had starter problems I n the past so maybe the ground wire isn't seated properly.
Old Sep 29, 2013 | 04:59 PM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Re: No spark
I ran another ground wire from the battery to the engine block and still no spark. I tested the ground on the block with multimeter and it checks out fine. I also checked the coil and get 12 volts inside the cap. For some reason im not getting a ground on the heads it appears. I even tried running a ground wire from the battery to the head and still nothing when it turns over.
Im not seeing any loose wires touching anything on the engine so im baffled.
Anyone got any ideas? After a lengthy restoration this is the last thing holding me up.
Old Sep 29, 2013 | 06:10 PM
Ransford2987's Avatar
Car: 1990 IROC-Z/1980 Firebird
Engine: 5.7 TPI
Re: No spark
I've added the positive and negative batter cable diagrams from my 90 Camaro manual, which should be the same. Maybe that will help? I've read your post here and I'm not sure how you're losing spark. Check the resistance to ground with the each head. They should be the same as the block, but you never know. Or you could try and jumper the battery to the head with some jumper cables just to see if you get a spark, but that's a little dangerous I guess.
Attached Thumbnails No spark-20130929_190009.jpg   No spark-20130929_190048.jpg
Old Sep 29, 2013 | 06:59 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: No spark
... I tested the spark at the plug it was not touching anything metal and it didn't spark
The plug body has to be touching a battery ground somewhere ;if the plug doesn't have a path to ground it will do nothing as you found out
Not uncommon.
Your spark may be "strong" enough for you to visibly see on the outside but too "weak" to fire when covered in fuel under pressure inside the cylinder
Old Sep 29, 2013 | 09:33 PM
patricklav's Avatar
Car: 92 Camaro Z
Engine: LS 5.3 LM7
Re: No spark
Not uncommon.
That makes sense. What would cause a weak spark? Too large a gap? In have them gapped at .55 right now. I checked the entire distributor , cap and rotor and everthing is getting voltage and grounded properly so it could be a weak spark like you suggested. I have vortec heads and the plugs came gapped at .65 out the box. I lowered the gap to .55 but now I'm wondering of the HEI can support that gap.
Old Sep 29, 2013 | 10:44 PM
Engine: 5.7 TPI
Re: No spark
Check the label on the hood, as I think it's .035" (I looked it up after: http://www.iroczone.com/2009/10/1990...pecifications/). You can also check the resistance to the plugs if you're worried about that, but one or two spark plugs with a higher resistance wouldn't cause a no start.
Old Sep 29, 2013 | 11:02 PM
InfernalVortex's Avatar
Car: 1992 Camaro RS
Axle/Gears: 9-bolt 3.70
Re: No spark
.055 seems high. I think I normally gap around .040. I'd tighten the gap a little to see if it helps although I doubt that's the root of the problem.
Old Sep 30, 2013 | 12:42 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Re: No spark
Plugs are not gapped from the factory.
One spark plug number may fit many different makes and engines , all with different requirements
You have to gap them to the listed spec to suit your particular application.
Old Sep 30, 2013 | 02:33 AM
Arizona IROC's Avatar
Car: 1989 IROC
Engine: 305TPI
Axle/Gears: 2:73 posi
Re: No spark
A friend of mine had a similar problem but all I had to do is take off the cap and unhook all the wires feeding the distributor and coil, blow them off with the air hose and hook them back up.
Look around for any obvious corrosion, shorts or carbon and make sure there are no pinched wires.
I never did find out what the problem was because it started right up when I was done and hasn't failed since.
RedLeader289
May 28, 2019 01:47 PM
Bubbajones_ya
Oct 25, 2015 08:01 PM
HoosierinWA
Oct 7, 2015 10:15 AM
meeklay812
Oct 1, 2015 03:46 PM
HoosierinWA
Members Camaros
Sep 29, 2015 12:43 PM
