Code 44 lean exhaust, cannot find the problem
Old Sep 30, 2013 | 07:20 PM
GreekItalianMan's Avatar
Car: 1986 Trans Am
Engine: lb9 305 tpi
Transmission: THM700R4
Axle/Gears: Posi-rear,3.27 9 bolt Borg Warner
Hey guys, I have an 86 trans am tpi, I have been troubleshooting this thing for months and I can't get it to run right. I've thrown so many parts at it and i can't get it running right. I've replaced a boatload of sensors that were throwing codes and it;s a lot better but still running like crap. Please, My gas mielage is like a trucks and theres no power to the car most of the times, it idles horribly on cold start up and i have to drive it for a minute or two to get it to even run without almost dying or stumbling and hesitating. After its warm it runs better but still every time its started will idle roughly and stumble until driven. Also, for some reason when its first started and run, when I go to a stop, itll almost die and after doing this, itll run and not do that, but then run like crap with no power..... I'm out of ideas
Old Sep 30, 2013 | 07:55 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Code 44 lean exhaust, cannot find the problem
Have you done the DTC 44 diagnostics?
http://www.chevythunder.com/o2_sensor_code_44.htm
Did you replace the O2 sensor
Is the 44 the only code showing at present?
Old Sep 30, 2013 | 09:19 PM
Car: 1986 Trans Am
Engine: lb9 305 tpi
I wasn't aware of this test haha, the diagram is a little confusing, sorry, I'm new to this diagnosing stuff. Are you supposed to run the engine with the paper clip in? I replaced the 02 sensor barely a year ago. And it's the only code I'm getting now. Before it would come and go with the tps until I got that replaced and adjusted now it's just showing the code 44 and the ses light wont come on, but the code is stored.
Old Sep 30, 2013 | 09:49 PM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Does the light come on with the Ign ; as in when you 1st turn the key on?
Have you cleared the codes to see if the 44 comes back?
Old Sep 30, 2013 | 10:34 PM
IROCgiraffe's Avatar
Car: '87 IROC-Z | '99 SS
Engine: LB9 | LS1
Transmission: 700R4 | T56
Check the MAF. Only code mine was throwing was the lean code after I replaced some items. Car still has the original O2 (its not coming out) and no more codes. Runs a lot better as well.
justin57
Aug 20, 2015 07:05 PM
gta power
Aug 13, 2015 06:15 AM
apie2546
Aug 10, 2015 05:43 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
