How many quarts do i need
Old Oct 5, 2013 | 01:38 AM
jpach1990's Avatar
Car: 1984 Trans Am Recaro
Engine: 5.0L V8
I need to do a flush on all the fluids in my car so the transmission fluid, coolant, brake fluid, and oil i need to know about how much i need to get of each one so i can flush and refill
Old Oct 5, 2013 | 06:06 PM
maxjivi05's Avatar
Re: How many quarts do i need
If the Transmission is a 700R4 takes around 11Quarts. If its a standard a lot less. The rest not sure..
Old Oct 7, 2013 | 08:49 AM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
read your owners manual...
Old Oct 7, 2013 | 09:37 AM
Codename 47's Avatar
Car: 1986 Camaro Z28
Engine: 400
Axle/Gears: 10 bolt Posi 3.73
Yep, owners manual or a service manual. Worst case if you contact a dealership they should be able to check the service manual for you. Good luck.
Greg
Hotrodboba400
Dec 10, 2019 07:07 PM
abray1
Sep 14, 2015 08:18 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
Navy8125
Aug 17, 2015 01:29 PM
