CAMSHAFT, WILL IT WORK?
Old Oct 8, 2013 | 12:44 AM
Jake_92RS's Avatar
Car: 1992 Camaro RS, 2012 Camaro SS 45th
Engine: L03 305 TBI V8, Blown 6.2L LS3
Transmission: 700R4, TR6060
Axle/Gears: GM 7.6" 10 Bolt 2.73
Say I wanted to buy a comp cam for my carbureted 350 that is a hydraulic roller cam with a 110 degree lobe sep and a rpm operation range of 1900 - 5400, is it absolutely necessary to buy a stall converter or can it be used on the stock torque converter from a 92 Camaro RS?
heres the link:
http://www.compcams.com/Company/CC/c...?csid=581&sb=2
Old Oct 8, 2013 | 04:19 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: CAMSHAFT, WILL IT WORK?
You will not be happy with the driveability with that cam and a stock TC and 2.73 gears.
Old Oct 8, 2013 | 06:47 AM
86LG4Bird's Avatar
Car: '86 Bird, 96 ImpalaSS, 98 C1500XCab
Engine: LG4, LT1, L31
Transmission: 700R4, 4L60E, 4L60E
Axle/Gears: 3.73 Tors, 4.88 spool, 3.73 Eaton
No, it will not work.
That's a big block cam
Old Oct 8, 2013 | 07:04 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
I third that, you will be loading up the engine with fuel at lower RPM. Washing the cylinder walls with gas and surely an early death for your motor.
Old Oct 9, 2013 | 03:30 AM
Jake_92RS's Avatar
Yeah I noticed that and then I felt stupid. lol. But still, I'm looking for a pretty aggressive cam that will be a good street performance and drive-ability, for a 350 sbc, preferably on a stock TC, and on gears that could range from 2.73-3.73.
Old Oct 9, 2013 | 05:57 AM
86LG4Bird's Avatar
IMO, 224 intake duration will be far too much for a stock TC.
In my experience, even with stock cams, a converter change is worth more bang for the buck than a cam swap.
I'd go no more than about 208 duration if you're intent on keeping the stock TC. And even then, that number is dependent upon what kind of lobes you're dealing with. Example: Comp XE lobes will have less seat-to-seat duration for a given .050" number, so something like a Comp XE 206/212 cam would be acceptable for a stock TC. On the other hand, the ZZ4 cam in my truck (208/221/112), with slower lobes and more seat-to-seat duration, absolutely fell on its face after each gear change when I tried it briefly with the stock TC; but provides uninterrupted power with the Yank SS3600 in it now
Until you go with 3.42 or steeper gears, I wouldn't bother with a cam swap.
Old Oct 9, 2013 | 06:13 AM
1gary's Avatar
Gotta know that cams by themselves are NOT a independent part.That much of the cams need to be matched to the SRC.Here is the link:
http://www.crankshaftcoalition.com/w..._compatibility
The SCR + the wt of the car + the stall + the rear end ratio + the tire size + the above all need to matched. All that and I am going to add in the next formula for your ref.
http://www.wallaceracing.com/eff-cr.php
These things are very important factors for it to work.
Old Oct 9, 2013 | 06:19 AM
86LG4Bird's Avatar
Yep. Another reason to be careful of too much intake duration.
That 206-208 suggestion is as far as I would go with stockish (~9.0 to 9.5) CR.
Caspar
Jun 19, 2016 11:19 PM
Reddeath210
Oct 6, 2015 08:20 AM
gta90
Sep 15, 2015 04:00 PM
Fronzizzle
Aug 17, 2015 02:52 PM
Jake_92RS
Aug 17, 2015 09:42 AM
