spark plug heat range lo5 350?
Old Oct 9, 2013 | 02:45 PM
Project86B4Z's Avatar
Car: 85 camaro RS RIP\ 86 IROC-Z :)
Engine: 2.8 MPI V6\ carbed LO5 5.7 v8
Transmission: 700r4 auto
Axle/Gears: 3.42\ posi 3.73
I finally got the 350 in and I'm running the AC delco hei non ecm ignition system with an edelbrock 1406 (600) I want to know what heat range my plugs should be along with the gap and ignition base timing
Old Oct 9, 2013 | 03:14 PM
Re: spark plug heat range lo5 350?
Also would like to mention I'm running headman long tubes with 3" collecters and flopro muffler
Old Oct 9, 2013 | 04:04 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
Stock internals on the 350? I'd give a stock replacement plugs a try and go from there. Once you find what you like, then buy the more expensive ones. Also base timing is typically 6-10 degrees, it all depends what you engine likes, theres not set number to give.
Old Oct 9, 2013 | 04:22 PM
bone stock 350 long block with swirl port heads carb and headers and iron 4bbl intake for now im thinking that my heat range is a little too low im running ac delco rts42 with .035 gaps
Old Oct 9, 2013 | 10:56 PM
Fast355's Avatar
Car: 1983 G20 Chevy
Transmission: 4L60
42 heat range is what I run in my 305s/350s and have never had an issue.
eightsixseven
Dec 16, 2024 01:50 PM
1992 Trans Am
May 10, 2023 07:19 PM
evilstuie
Feb 28, 2016 03:33 PM
Red iroc-z 305
Sep 30, 2015 05:22 PM
