Steering column issue
Old Oct 11, 2013 | 02:29 PM
Poiskd's Avatar
Car: 92 RS
Engine: 3.1 MPFI V6
Hello everyone, just recently joined the forum and just recently got a 92 camaro RS 3.1v6 for 900, its got a few issues which I cant figure out.
Mainly, the steering column is loose, doesn't lock, can move it up and down freely, and there's also a bit of play to the wheel. Additionally, when turning sharply theres a noticable cracking sound, and I cant figure out whats going on with it. Any help would be greatly appreciated, thanks!
Here's some pics of the car although they dont really show much in relation to the issue. - http://imgur.com/a/bwXd7 -
Old Oct 11, 2013 | 03:15 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Re: Steering column issue
Welcome to the forum! There are normally 2 different types of "loose" column. Does yours feel like a loose tooth? Or does yours have spring tension and you have to pull it to move it around? The second one is more common for the 90-92 airbag wheels.
As for it not locking in place that seems odd, perhaps a previous owner took the column apart to investigate and pulled the lock teeth apart and didn't put them back in correctly? The wheel is always in the most upright position?
If it's the loose tooth column maybe one or more of the bolts backed out completely and are binding up while you're turning and that is the cracking sound you're getting?
Old Oct 11, 2013 | 03:18 PM
Poiskd's Avatar
Car: 92 RS
Engine: 3.1 MPFI V6
Wheel is always in the most downright position, and it moves very slightly side to side, but can freely move it on its full range of motion up and down, and then if i let go of it it just drops all the way down. It does not pull outward at all, so it's still being secured by something at least.
Old Oct 11, 2013 | 03:52 PM
mcgarnicle's Avatar
Car: 1991 Z28 1LE
Sounds like the retaining screws backed out and it's just hanging. I believe there is an article in the Tech Article section about how to tighten up your column. You're going to have to open up the column to see what is really going on in there, and you're gonna want to buy a few tools if you don't have them already particularily the lock plate hold down tool.
Old Oct 11, 2013 | 08:08 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Welcome to thirdgen.
Out-Cast
Mar 22, 2019 09:39 PM
evilstuie
Feb 28, 2016 03:33 PM
Oenone
Aug 29, 2015 07:54 PM
Out-Cast
Aug 23, 2015 06:33 AM
Bull86
Aug 10, 2015 05:43 PM
