86 trans am drivers headlight
Old Oct 12, 2013 | 06:57 PM
806camaro's Avatar
Car: 1990 IROC
Have an 86 trans am just purchased it a few weeks ago. The drivers headlight had a delay before engaging to flip up. Now it won't even flip up, but when you twist the **** for it to come up it will flip back down when turn the headlights off. I have searched around, but haven't found really what I'm looking for. Is a relay, or is the motor bad?
Old Oct 13, 2013 | 12:22 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: 86 trans am drivers headlight
Keep on searching, there are many threads that cover this topic in detail.
Most likely problem is the drive bushings in the headlight motor have crumbled. Can be repaired with a kit, or if you're as cheap as I am you can fix it for almost free using a piece of rubber hose.
Old Oct 13, 2013 | 05:25 AM
806camaro's Avatar
Car: 1990 IROC
How did you fix it with a rubber hose?
Old Oct 13, 2013 | 06:36 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
https://www.thirdgen.org/forums/body...ml#post5603571
1992 Trans Am
May 10, 2023 07:19 PM
The_Phoenix
Feb 4, 2016 07:10 AM
Greg '85 T/A
Aug 14, 2015 01:40 PM
timonator
Aug 11, 2015 09:56 PM
blacksunshine'91
Interior Parts Wanted
Aug 10, 2015 12:04 AM
