Engine cranks, no start, fuel leak
Old Oct 15, 2013 | 10:54 AM
TheBallPlayer's Avatar
Car: 1990 Camaro RS
Engine: 5.0 TBI Edelbrock Intake
Axle/Gears: 3.73 Posi
Hey guys I have a 92 rs 305 with a 5 speed in it. The car was running pretty good except it would over heat once in a while. One day I went to start it up and it was just cranking and not starting, and I could smell fuel. Well there was fuel dripping from the exhaust under the engine. And my oil smells like fuel. Any ideas? I pulled code 13 but I don't think that has to do with the problem. The engine was just running great the other day
Old Oct 15, 2013 | 05:19 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Engine cranks, no start, fuel leak
Originally Posted by TheBallPlayer
I could smell fuel. there was fuel dripping from the exhaust under the engine. And my oil smells like fuel.
A busted diaphragm in the reg allowing fuel to be sucked straight into the intake comes to mind.
Check the injectors are they leaking fuel ; KOEO ?
Old Oct 15, 2013 | 06:03 PM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
When you get this fixed you will want to get that oil and filter changed. FWIW.
Spyder_TheGamer
Dec 25, 2015 05:07 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
Tonyy_z
Aug 12, 2015 07:20 AM
mizz0313
Aug 12, 2015 06:45 AM
92projectcamaro
Aug 6, 2015 01:20 PM
