High Oil pressure
Old Oct 19, 2013 | 07:12 PM
Noodles's Avatar
High Oil pressure
Hey i have been noticing a bit high oil pressure. Cold start it goes right up to 60 psi and any acceleration brings it to 60-80 psi. After about a 10-15 min drive, or up to temperture(about 190), it goes back to normal 40-60 psi. This is a new engine it has about 4.4k miles on it. I haven't changed the oil on it yet but will once i get some money. could this be the problem or is it some valve?
Old Oct 19, 2013 | 07:51 PM
Re: High Oil pressure
Probably ALOT worse.
The oil pressure sending unit probably has wore out. That's going to set you back about a cool $20 or so, and waste about 15 minutes of your life you won't be able to get back.
Old Oct 19, 2013 | 07:57 PM
Noodles's Avatar
lol thanks for the help
89GTAOz
May 16, 2020 09:31 AM
xxx3man`
Sep 23, 2015 10:37 PM
355sbcTPI
Aug 19, 2015 04:38 PM
bamaboy0323
Aug 15, 2015 07:20 AM
