AC compressor blocking valve cover
Car: '84 Camaro Sport Coupe
Engine: 355
Axle/Gears: 3.08
Have any of you guys modified the AC compressor mounting position so that you don't have to loosen it out of the way every time you want to remove your driver's side valve cover? (non-serpentine belt set up) (compressor to valve cover interference circled in green)
Also, has anyone remove this bracket support bar without ill effects? (bar circled red in picture) I just want to make sure the AC compressor would still be mounted securely.
Re: AC compressor blocking valve cover
MoJoe
Sep 24, 2015 09:12 PM
NBrehm
Aug 25, 2015 11:49 PM
Street Lethal
Aug 12, 2015 11:33 AM
