whats involved in a cam install?
Old Oct 22, 2013 | 02:20 AM
Dabesiv's Avatar
Car: 1982 Camaro Berlinetta
Engine: GM crate motor Goodwrench 5.7 350
So on my very long list of things to change on my car to make it faster, there is the camshaft. I am not very knowledgeable in engines and am still learning, but as far as i have gathered, just changing the camshaft, and maybe lifters etc. (depending on the rise of the shaft) can moderately improve the performance. I have seen many people post about it being a cheap mod for good results, and looking at prices for them, it is cheap. When i asked my mechanic (he handles all the things I still can't do) what it would cost, he said it's more expensive than I would wan't to pay, he quoted around $1000+ for labor. I think the most I have ever paid for labor on a repair was $500-$600 for a heater core. So exactly what is so labor intensive about the camshaft that would make it that much? At first I thought it was that they would have to pull the motor, but I don't see a problem with them being able to do it with the front bumper and radiator removed instead, but I am only going off what I have seen as far as how it is to be installed. Again, sorry for my lack of know how on the engine things, it's a slow process to get it all down.
Old Oct 22, 2013 | 05:55 AM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: whats involved in a cam install?
It's a big job if the engine is in the car. Intake, rocker covers, and timing cover all have to come off and the oil pan needs to be lowered. There is a body bracket that needs to be removed so the cam can phisically be removed from the engine. And while pulling the cam, someone needs to hold the condenser up out of the way while you fish the old cam out and slide the new one in.
I did a cam swap last winter on a car that was equipped with A/C, TPI, and full emissions in tact. It's quite a tedious task if you're trying to preserve all the original connectors, wiring, and tubing.
Old Oct 22, 2013 | 06:40 AM
Edwardgp's Avatar
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Old Oct 22, 2013 | 12:27 PM
Dabesiv's Avatar
wow, much more then expected. I do have A/C, the CC Carb, and all emissions still intact so I am sure that adds more issue. I guess I will hold off on the cam until the next engine. Thanks guys!
Old Oct 22, 2013 | 04:37 PM
Reddeath210's Avatar
If the engines out of the car, would it be nearly as hard?
Old Oct 22, 2013 | 04:55 PM
NagleMac's Avatar
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
If the engine is out all you do is oull the old one out and put the new one in. simple as that
Old Oct 22, 2013 | 05:14 PM
eseibel67's Avatar
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Ya, if the engine is out of the car it's a piece of cake.
Old Oct 24, 2013 | 01:38 PM
1gary's Avatar
Degree-ing the cam....anyone??.
Old Oct 24, 2013 | 01:43 PM
FRMULA88's Avatar
Car: 1988 Formula
Engine: 421 Little M block
Transmission: TH400 w/brake
Axle/Gears: 9" 4.30s, Wilwood discs, 28X10.5-15
"dot to dot", for most of these street cars that should be fine. LOL
We degreed the cam in my 421 the first time.. to make sure the cam specs were correct.
But on the redos.. it's just been "dot to dot" no sence re-degreeing the same camshaft .
Old Oct 24, 2013 | 10:31 PM
1gary's Avatar
There are in the aftermarket and GM cams that are 4 degrees advanced.
Vintageracer
Jan 10, 2020 05:33 PM
anesthes
Mar 10, 2016 10:35 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
theurge
Aug 21, 2015 12:46 PM
drathaar907
Aug 6, 2015 04:20 PM
