power braking issues
Car: 1986 camaro Sports Coupe
Engine: L31 350
Transmission: 89 700R4
Axle/Gears: 3.42 gov lock
I noticed an issue tonight while I was power braking with a friend. After a certain rpm, my vortex kinda lames out, like it just quits screaming and stays at one rpm. Is this normal or is something off? Now I know that power braking isn't the best and I never do it, never really have too since this car will roast the tires without the brakes but can anyone give me some in site in what's going on?
Car: 1989 Iroc-Z Camaro
Engine: TBI,5.0
Transmission: Automatic 700R4
Re: power braking issues
If your spinning the tires at WOT is it possible you're hitting a speed limiter ?
Engine: L31 350
With a carved motor? I'm running hei for a distributer so I didnt think I had a speed limiter,
Engine: TBI,5.0
Sorry, if you don't have a ECM then obviously you don't have a limiter.
Car: 1983 BB 1995 Z28 Camaro's
Engine: 454-350
Transmission: TH350-4l60e
Axle/Gears: 373 posi-Stock
Will have to think on this one a bit. What rpm does it become stationary?
Engine: L31 350
Not real sure since I'm running the original v6 tach still but its around the top of first gear I'd say 4500 rpm?
Engine: L31 350
Didnt think of that but im running a stock cam with upgraded valvesprings( alex springs) so I didnt consider that, what the motor does is it revs alittle higher than normal then drops downn to where it stays till I let off the brake then I think it comes back up to its higher rpm. Would over tightened rocker arm nuts do this?
