VIN code for T5?
Car: '91 Camaro RS
Engine: Carb'd 383
Transmission: Built T5
Axle/Gears: 3.73 Posi
VIN code for T5?
Anyone have a T5 with an ELECTRONIC speedo that can PM or let me know what their VIN number is? I swapped a T5 into my 91 camaro (used to be auto) and now I need a new speed sensor (mine leaks). Dealer says i need the VIN number so they make sure I get the right part. It's a special order part that can't be returned, so i dont want to take a chance and end up losing $85.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
Re: VIN code for T5?
http://www.ebay.com/itm/Chevrolet-Camaro-Z28-Coupe-2-Door-1991-chevrolet-camaro-chameleon-paint-305-v-8-70-k-original-miles-/181255533132?forcerrptr=true&hash=item2a33abf24c&item=181255533132&pt=US_Cars_Trucks#ht_420wt_880
Car: 1985 Trans Am T-Top
Transmission: T-5 5 Speed
Axle/Gears: 3.42 posi 1LE 10 bolt
There's nothing in the vin to indicate transmission. Just give them your vin to match up the engine.
Car: 1988 GTA
Engine: LB9
Axle/Gears: 3.45
I don't think it can. The details available in the computer are limited for pre 91 cars. They are just asking for the VIN because that's what they are told to do. The dealer will not learn anything from the vin besides the engine code. If you give them the vin from an auto car, they won't know the difference.
Car: '91 Camaro RS
Engine: Carb'd 383
Actually what i need is the RPO code I believe. Anyone have that?
Here's the parts and codes.
http://www.gmpartsdirect.com/catalog/frameset.cfm
What will the RPO code tell them? All you need to know is exactly which tranny you swapped in which won't have anything to do with your VIN or RPO.
Car: '91 Camaro RS
Engine: Carb'd 383
The RPO code is actually for the speed sensor itself, not the trans. Found the code from my originally auto camaro, and purchased the opposite one. Will update when I get the part so anyone else with this same problem can get the right one.
