91 L98 TPI Camaro Stating Problem
Old Nov 16, 2013 | 02:45 AM
TipTricky's Avatar
Car: 1991 Chevy Camaro Z28
Engine: 5.7lt TPI L98
Axle/Gears: Drum Brakes, Not Sure Gears
So i just picked up a 91 camaro off craigslist for 500 dollars and a triple A tow home but its not starting. The battery in it is toast so i used the battery out of my crown vic which is 700 cca and you turn the key on and the fuel pump primes and you turn the key and the starter just clicks rapidly. It turns the motor about a degree and then clicks fast. Lights are bright and the battery load tested fine so i was wondering is it more likely that the starter is bad or the solenoid?
Old Nov 16, 2013 | 10:28 AM
TipTricky's Avatar
Re: 91 L98 TPI Camaro Stating Problem
Solved
Old Nov 21, 2013 | 06:15 PM
jtsk's Avatar
Car: 1992 z28 Purple Haze
Engine: 5.7L Tuned Port Injection
Axle/Gears: 3.23 both spinning
The suspense is killing us! What was the issue?
Vintageracer
Jan 10, 2020 05:33 PM
onefreakz
May 14, 2018 12:15 PM
NBrehm
Aug 25, 2015 11:49 PM
Linson
Aug 21, 2015 02:12 PM
matthew911
Aug 12, 2015 09:38 AM
