Tach help!
Old Nov 20, 2013 | 10:11 PM
jess68starr's Avatar
Car: 89 GTA
Engine: 6.2 ls3
Axle/Gears: 3:73
Tach help!
I think my tack is going bad in my 90 gta. The fuel gauge says 1/8 when it's empty and m oil gauge is always past 80. Is this right..?! If not. Is there any way I can swap it from te existing 120mph to a 145mph one without any issues at all?
Old Nov 20, 2013 | 11:37 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: Tach help!
If you have a a wiring or sensor problem ,then swapping the cluster won't help.
You need to work out WHAT is wrong 1st
Tests need to be done
Old Nov 21, 2013 | 10:30 AM
Car: 89 GTA
Engine: 6.2 ls3
Axle/Gears: 3:73
Re: Tach help!
Then where do I start? How do I go about that
$750 L98
Feb 1, 2025 02:25 PM
86maro_252
Oct 10, 2015 06:52 PM
Eric-86sc
Sep 28, 2015 11:37 AM
RedLeader289
Sep 23, 2015 06:50 AM
TrevinE
Sep 14, 2015 03:20 PM
