solid roller lifters on a hydraulic roller cam
Old Dec 4, 2013 | 08:27 PM
baddone88ta's Avatar
Car: 1988 Trans am gta
Engine: 396 Stroker sbc
Transmission: 700r4 3000 stall
Axle/Gears: 9 bolt posi 2.77 gears
Has anybody used a set of solid roller lifters on a hydraulic roller cam ? I have searched the web and it seems like 50/50 whether it will work or not. I have a comp cams 12-602-8 cam and a set of doug herbert horizontal bar solid lifters. The springs I have are rated for up to .600 lift for a flat tappet cam but I have also purchased some solid roller cam springs that have 190 lbs @ 1.900" and 620 lbs @ 1.150" and coil bind at 1.080 if i need to change them. I was just wondering if this would work or if its more trouble than its worth. If any body that's done this some feed back would be greatly appreciated. I don't want to ruin any parts that's why I'm asking thanks in advance
Old Dec 4, 2013 | 09:58 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: solid roller lifters on a hydraulic roller cam
What are you trying to achieve ?
Did you see this
"Successfully running solid lifters on a hydraulic profile requires some amount of valve lash .
This lash effectively reduces cam duration, especially at low lift off the valve seat
With less duration, peak torque and power occur at lower rpm than would normally be the case for the combo if running a hydraulic lifter
in other words, the cam acts smaller".
Old Dec 4, 2013 | 10:13 PM
Won't ruin any parts, in and of itself; just, probably won't run near as good as a correct solid cam of equivalent specs would. Which, given that the part # looks like one of the "Thumpr" cams, you probably don't need to give up any more of that than you have to, since you're already kinda short in that dept.
I'd buy the right cam, if it was me.
Old Dec 4, 2013 | 10:16 PM
AlkyIROC's Avatar
Car: 87 IROC L98
Engine: 588 Alcohol BBC
Transmission: Powerglide
Don't expect similar performance to an identical solid cam. Lobe profiles are completely different. A hydraulic lifter has a profile designed to work with a preload setting inside the lifter. The ramp is a different shape than what a solid cam requires with valve lash.
To save a lot of headaches and possible premature failures, use solid lifters on solid cams and hydraulic lifters on hydraulic cams.
Old Dec 5, 2013 | 03:50 AM
1gary's Avatar
no
Old Dec 5, 2013 | 08:49 AM
Thanks for all the input. I have read about running with a tighter valve lash and how it changes the duration and the characteristics of the cam. I have a set of solid roller litters and thought I could save some $$. I'll probably trust save up and get the right litters. Thank you guys again for the help!
Old Dec 5, 2013 | 11:10 AM
3rdgenmaro's Avatar
Car: 88 IROC
Engine: 97 5.7 Vortec LT4 hotcam
Transmission: 700 r4
Why not save up and get a better cam?
Old Dec 5, 2013 | 11:17 AM
I will probably do that I just need to figure out which way I way I want to go.
Old Dec 5, 2013 | 02:30 PM
3rdgenmaro's Avatar
Car: 88 IROC
Performance > Sound
Old Dec 5, 2013 | 03:55 PM
DeltaElite121's Avatar
Car: 1988 Camaro
Engine: 377
Transmission: TH350; Circle D 4200 converter
Axle/Gears: Ford 9"
This will ALWAYS get you in trouble. Don't try to be "thrifty" or you'll more than often end up with subpar operation and a fistful of problems to go along with it.
Old Dec 5, 2013 | 08:50 PM
Zackly... there's a time and a place for keeping expenses down, and other times and places where EVERY PENNY you spend brings puts back 2 PENNIES in your pocket.
The secret of life is, {drum roll pleeeeze} knowing which is which.
This would be one of the latter. Won't take very many tanks of gas, or buy-backs in rounds you lost, for that "free" cam to start COSTING you money.
Get the right cam.
Old Dec 5, 2013 | 10:50 PM
talked with comp cams today and I'm buying their 12-443-8
cam kit with all the right parts Thanks for all the advise!
Jorlain
Oct 8, 2015 01:57 AM
Strick1
Sep 4, 2015 07:11 AM
jtwoods4
Sep 3, 2015 05:39 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
z28guy134
Sep 1, 2015 11:50 PM
