AFR heads
AFR heads
Hi all, first post here. I just picked up an IROC with a ZZ4 short block and AFR heads. Trying to figure out which ones they are as owner had no specs on them. The only stamping I can see are 195. 3H, on top of that is 621 F. Any help would be appreciated. Thanks
Car: 89 Iroc-z
Engine: 555 BBC Turbo
Transmission: TH400
Axle/Gears: MWC 9” 3.00
Re: AFR heads
No other numbers on the front or back of the head casting? How about under the valve covers?
Car: 89 Iroc-z
Transmission: TH400
Re: AFR heads
Doesnt sound like eliminator series so it must be an older casting. 195 may be the afr 195cc heads pre-eliminator
92projectcamaro
Jan 18, 2016 08:00 AM
New2Chevy
Sep 28, 2015 12:35 AM
