91 MAP Harness into 85 MAF car
Old Dec 13, 2013 | 09:25 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Engine: 383 TPI Procharger D1SC
Transmission: TKO600
Axle/Gears: Strange S60 3.73
I searched but really couldn't find an answer. I will be converting my car over to a speed density set up for when I supercharge it. My question is will a MAP harness from a 91 car swap directly over to my 85 car that came as a mass air flow car? I'm not sure if it matches up directly with the harness connector that's on the firewall and or if there are any other modifications that need to be made? Thanks
Old Dec 14, 2013 | 11:18 AM
RBob's Avatar
Car: check
Engine: check
Transmission: check
Re: 91 MAP Harness into 85 MAF car
Mike shows how it is done:
http://www.eecis.udel.edu/~davis/z28/ecm_swap/
Note that he first swaps to an '86-'89 ECM, then on to the '7730 ECM.
RBob.
Old Dec 14, 2013 | 02:22 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Thanks for the link. My car is already converted over to the 86 to 89 maf computer and wiring harness. I don't need to be switching between map and maf as he does, I want to just stick with only the speed density set up from now on after the blower install. That being said, is all the work he does really necessary for me, or is it as simple as removing the maf wiring and ecm set up and replacing it with the speed density harness and ecm? Then all that is left is to change the knock sensor and install the map sensor.
Old Dec 14, 2013 | 02:39 PM
Dyno Don's Avatar
Transmission: Tremec T-56
Axle/Gears: 12 Bolt 3.73
No, the pinouts are different on the bulkhead connector.
You could go to the work of changing that part.
It's not that difficult.
Old Dec 14, 2013 | 03:20 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Would I have to get a bulkhead connector from a speed density car or does anybody know the pinouts off hand? Thanks again for the help.
Old Dec 14, 2013 | 03:43 PM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Here is the information on c100 and c207
https://www.thirdgen.org/forums/engi...s-am-help.html
Old Dec 14, 2013 | 04:10 PM
85Iroc-Z's Avatar
Car: 85 Iroc-Z
Those pictures should provide what I need. Is it easier to change the pinouts on the engine harness side to match the connector already on my cars firewall, or vice versa?
Old Dec 14, 2013 | 04:12 PM
Engine: Lb9
Transmission: M20
The easiest change the tpi harness. If you need programing assistance vats removal, a starter tune before you datalog if your going 383 send me a pm
midge54
Sep 2, 2020 07:13 PM
9192camaro
16
Feb 3, 2019 12:21 AM
NBrehm
Aug 25, 2015 11:49 PM
jharrison5
Aug 19, 2015 05:53 PM
squiggy2
Aug 9, 2015 09:30 PM
