Fuel Pump Push Rod
Car: Met. Silver 85 IROC/Sold
Transmission: T-5 (Non-WC)
Fuel Pump Push Rod
If the pump should fail, what kind of damage, if any, would/could the push rod sustain?
JamesC
JamesC
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Fuel Pump Push Rod
failed like you mean the push rod is concaved or mushroomed on the cam eccentric side ? if the pump fails its the diaphragm that fails or the lever may break overtime. Replace it and call it a day.
JamesC
Engine: Lb9
Transmission: M20
Chances are all the damage that is done is the fuel pump it self sounds like the diaphragm is ripped and fuel is coming out the weep hole. I would still take the time to remove the plate and take out the rod for inspection. If it has severe wear toss in a new one and the cam lobe should still operate it fine. Putting a thin coating of vasoline on the rod will help keep it up during assemble and has a low melting point.
This metal on metal sound , can you try to describe it ?
The reason I ask is , No matter how badly the pump failed , at a cranking over but not running engine speed , the worse sound I could imagine it would make might be a steady , repeating "Click , , Click , , Click" as the pushrod attempted to actuate the somehow failed pump . The metal on metal nature of the sound makes me wonder if more than one problem could be happening ?
Hi James ,
I don't want to worry you by speculating what could make such a screech sound , but , even at the low RPMs the engine was likely running it still , I would think , have more of a "click Click Click" nature to the sound rather than a screech .
I sure hope my hunch is wrong , but I do suspect you may have a leaking pump AND something else wrong (Stuck idler or air pump pully , perhaps ?)
I guess we'll have to see what it does when you replace the leaking pump .
PS , have you checked the oil to make sure the leaking pump hasn't diluted it with fuel ?
Well, never too old to be a numb nut.
I removed the card to give it another once over and what should I find from the install from a day or so ago? A washer—from nuts and bolts that I use for a carb stand—had stuck to the bottom of the carb base so that when I put the carb on the manifold, the washer created a massive vac leak. I know a vac leak can cause whistling, but I'm unsure that the caterwauling I heard could be attributed to that.
BTW, I checked pullies, and they spun freely and noiselessly, though they weren't, of course, under load. There was no smell of gas from the dipstick.
Everything is buttoned up, but I haven't cranked it yet.
Here's the link that started me down this road:
https://www.thirdgen.org/forums/carb...sues-fuel.html
JamesC
JamesC
Hi James , GREAT find on the washer stuck to the bottom of the carb spacer , Hell ya I'll bet that could cause exactly the Screech sound you described !
It's good that no fuel made it into your oil and I'll bet that with the carb squared away and a new non leaky pump installed , you'll be fine .
Please let me know if the mistaken washer was the source of the sound , I have heard lots of vacuum leaks over the years , and some did in fact screech just as you described
JamesC
92camaroJoe
Aug 13, 2015 06:07 AM
