Weird oil leak on intake?
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Just as the title says....I popped the good yesterday and found a small pool of dark brown fluid on the intake, I thought it might've been gas coming from the carb inlet. I cleaned it up and tightened the clamp for the fuel and then I took the car out last night, brought it in the shop to check it out because last night was car show night, changed the oil etc, looked at the same spot and there's another pool of fluid. I actually touched it with my fingers this time and it felt like oil and had no smell to it really..and I found out its on both side of the intake in the same place. Never seen an oil leak there before. Here are some pics...
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: Weird oil leak on intake?
Pull out the bolts and clean then. Then coat them with liquid Teflon sealer or Rtv.
Car: 84 Camaro z28
Engine: 355
Transmission: Th350
Axle/Gears: 4.10
Car: 85 Silver Iroc, 79 Camaro
Engine: LB9, 500+ ci BBC
Transmission: 700R4, th400 with brake
Axle/Gears: 3.42, hand made 40 spline 9"
maroe624
Apr 16, 2017 08:29 AM
ambainb
Apr 25, 2016 09:21 PM
Navy8125
Aug 21, 2015 09:32 AM
This is a commonly forgotten step while installing an intake.
