I recently started hearing a grinding/scraping sound coming from my engine
Car: 1987 Camaro sport
Engine: V6 2.8L
Axle/Gears: Stock
I was driving down the road earlier and just starting hearing random grinding/scraping sounds coming from what sounds like my engine. It doesn't make the sound in accordance with the RPM level however. What could this be?
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: I recently started hearing a grinding/scraping sound coming from my engine
Could be many things, your profile is incomplete. I would guess water pump or bent transmission dust cover or loose flex plate to tq bolt.
Car: 89 Formula
Engine: LB9
Transmission: 5 spd
Axle/Gears: 308
Had this same sound problem. It was my converters. they were blown and the sound was the rusty debris flying around inside the exhaust. Sure sounded like parts were flying inside of the oil pan.
db057
Aug 11, 2015 10:11 PM
