pcv valve broke
Car: 1985 pontiac firebird S/E
Engine: 5.0L 305 carb
Transmission: auto
pcv valve broke
yeah while i was messin around the engine bay i accidently broke what i assume is a pcv valve that connects to the engine . i also ended up losing some metal pin im guess it was a vacum nipple. my first question is me not having this connected will it be alright to drive the car around, how important is it and 2nd how do i go about replacing this cause i went to a few auto stores and they couldn't find a similar piece should i just go to a junkyard and see if i could swap it out there?
oh and last i changed my air filter and i saw that theres like a secondary one that goes into the orange plastic thing. i tried searching around but couldnt find anything about it anyone know what it called.
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: pcv valve broke
btw depending on what it controls the color usually indicates the opening temp. For example canada models use a grey tvs for spark control . that one is grey or purple acdelco 212-352.
You may have one for ccp. look at your vacuum diagram or follow the vacuum lines to determine were it goes.
Engine: Lb9
Transmission: M20
Re: pcv valve broke
you other pic in the air cleaner housing I'm surprised your auto parts doesn't have atleast a fram BA19DP or CA19 breather element.
Re: pcv valve broke
That looks like the green one, for the canister purge. Probably called something like "canister purge control TVS" or some such. http://www.autozone.com/autozone/par.../N-ik28fZ93xpw This one should work.
The air cleaner part is always available at the stores. It looks about like a piece of Scotchbrite; not very exciting. Might have to just look at things hanging on cards in the filter area. NDB though, it WILL be there.
tyeo098
Nov 30, 2015 06:27 PM
355tpipickup
Sep 13, 2015 11:35 PM
