Too much air?
Old Jan 21, 2014 | 09:12 AM
Ev.'s Avatar
Ev.
Car: '87 Trans Am GTA
Engine: 5.7L 350cu.
Axle/Gears: Stock
Too much air?
Hey guys, This past weekend I decided to remove my entire intake to do some cleaning(I hadn't realized how filthy my air filter was)and all went well. I cleaned a TON of buildup out of there. I also replaced my air filter with a high flow one. Now there's the problem, when I hit the gas the engine hesitates (like its taking a breathe) before it starts moving. I have a cool air intake, bostch injectors, a performance chip, and high flow exhaust too. It's never given me this problem until I cleaned everything! It almost sounds like it's out of gas, like the hesitation sounds similar to the noise that happens when you putter out of gas. Anyone know what i can do? Thanks everyone.
Old Jan 21, 2014 | 10:45 PM
Ev.'s Avatar
Ev.
Engine: 5.7L 350cu.
Axle/Gears: Stock
Re: Too much air?
Oh by the way, it's an 87 trans am GTA with the 350.
Old Jan 22, 2014 | 12:13 AM
92g92's Avatar
Car: 1992 Camaro Z28
Re: Too much air?
Hmmmm I am far more familiar with speed density cars but I can only assume it's sensor related. Considering you could run an exposed throttle body without any ducting or filters at all, your problem will have nothing to do with "too much air". Hopefully someone with more experience will chime in but my GUESS would be an MAF issue. Possibly? Taking for granted that the only things you removed were the TPI air duct and two filters, that is. Maybe you ripped or just didn't plug back in your MAF sensor, if it even has a plug. As I said, not much knowledge on MAF for these cars, but that's where I would say to look first. The sensor is a big round one in the middle of the rubber ducting just before the throttle body, if you didn't already know.
Old Jan 23, 2014 | 02:36 PM
Ev.'s Avatar
Ev.
Engine: 5.7L 350cu.
Axle/Gears: Stock
Re: Too much air?
Wow I feel stupid, one of the wires backed out of the connector to the MAF. Thanks for bringing it to my attention! I overlooked because i had no check engine lights! Thanks alot
Bubbajones_ya
Jul 6, 2024 08:32 PM
db057
Apr 28, 2019 07:45 AM
83 Crossfire TA
Jan 3, 2016 01:26 PM
edoff13
Sep 11, 2015 03:55 AM
scotrans am
Sep 5, 2015 04:26 AM
