V-belt power steering pulley??
Car: 92 camaro rs
Axle/Gears: 10b 3.73 posi
Can anyone please tell me where I can get a 2 groove power steering pulley v-belt style? I've looked everywhere and they all say diameter 5.8" and the one I have now is like 6.5". Are they interchangeable? The part number on mine says 14023173 gm. Any and All help appreciated!
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
Re: V-belt power steering pulley??
I can sell you one off a 85 tpi iroc, why do you need two groves ?
http://www.1aauto.com/1A/PowerSteeri...FStgMgod4QUA4w
Car: 92 camaro rs
The one I have now is 2 grooves. Would I need 2 grooves for ac? I'm hooking ac up as well.
Yes they are interchangeable; might need to use a slightly shorter belt.
Virtually ALL 82 - 87 or thereabouts, carbed cars had the 2-groove pulley. The inner groove was for either a PS only belt, or for a PS/WP belt depending on the WP pulley; the outer groove was PS/AC. Primarily AC.
Yer local buzzard nest is yer friend. Go chase em offa their carrion, see what they're sittin on. Odds are, you'll find one. Anything with a small block Chevy in those years. Caprice, Grand Prix, truck, Chevelle, you name it; doesn't matter; pulleys are the same.
A 5.8" one will spin your PS pump exactly 6.5/5.8 times as fast. NBD.
Engine: Lb9
Transmission: M20
Your right I forgot! I do have that pulley
https://www.thirdgen.org/forums/engi...cket-help.html
Engine: Lb9
Transmission: M20
Yes, did you need your vats bypassed as well ?
Car: 92 camaro rs
Is it the 5.8" diameter pulley or the 6.5" like I have now? As for VATS, I'm thinking about just bypassing it if it'll work.
Engine: Lb9
Transmission: M20
I will measure it alittle later tonight and let you know.
Engine: Lb9
Transmission: M20
Ipad posted it upside down , headstand
http://www.gmpartswiki.com/w/14023173&book=90
Engine: Lb9
Transmission: M20
The 85-86 tpi pulley is also marked 14023173
colton_carlson
Mar 8, 2019 12:21 PM
evilstuie
Apr 14, 2016 08:52 PM
sailtexas186548
Aug 24, 2015 10:11 PM
