1985 z28 power steering parts
Car: 1985 z28
I have a 85 z28 I bought the car the lines were looped together, I am trying to piece it back together. I have the pressure line, pump, pump pulley a new v-belt, and what I believe is the bracket. Anyone have detailed pictures or a website where I can find how it is set up I cant figure it out and I am having trouble finding vbelt specifiv diagram/pictures and even if I have the correct bracket? any help would be appreciate...
Car: 1985 z28
Re: 1985 z28 power steering parts
guess im missing a bracket, could I use this to reinstall the factory pump?
http://www.streetperformance.com/par...332-20165.html
or
http://www.summitracing.com/parts/br...t/model/camaro
or
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Thes might help:
With AC:
WithOUT AC
I've always re-used stock brackets so I don't know of any aftermarket products that will work.
With AC:
WithOUT AC
Car: 1985 z28
thanks yea that what I found after searching for hours on google that's how I figured out I was missing the front bracket. hopefully this one from summit does the trick
Car: 87 iroc-z
Engine: 454
Transmission: th350
kinda late, but skip white has a bracket that looks similar to your first link. i've not tried it though.
http://www.skipwhiteperformance.com/...px?Item=9105-P
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
I have a few of the brackets if you need them send me a pm
Engine: Lb9
Transmission: M20
No, I'll have to look to see what all I have but for sure I have part 11 and 8
Car: 1985 z28
thanks the parts I ordered will be here soon Ill try that if it doesn't work I will PM you. Ill report back asap. thank you for the help
Car: 1985 Iroc-z28
Engine: 5.7l TPI
Axle/Gears: Stock
1992 Trans Am
May 10, 2023 07:19 PM
colton_carlson
Mar 8, 2019 12:21 PM
backtothe80s
Sep 5, 2015 12:39 AM
