qwik ? bout v6 to v8
Old Feb 8, 2014 | 08:19 AM
budget builder's Avatar
Car: 91RS
Engine: carb'd 357 vortec
Axle/Gears: 3.42 posi
Just realized only two motor mount holes match up the bottom hole is not there when I moved the mount forward. Do I have to drill the hole out? Or is 2 bolts enuff on both sides? 92 rs from 3.1 to 5.7 auto tranny
Old Feb 8, 2014 | 08:21 AM
Car: 91RS
Re: qwik ? bout v6 to v8
Need to know b4 reinstalling control arm
Old Feb 8, 2014 | 08:36 AM
OrangeBird's Avatar
Car: 1989 Firebird
I could be mistaken , but , I thought even the parts that bolt to the frame are different from the 6 to the 8 cyl engine ? As in , you need the clamshells AND the frame mounted pieces from an 8 cyl and can't just slide the 6 cyl's frame mounted parts forward and bolt up to the 8 ?
Old Feb 8, 2014 | 09:44 AM
Car: 91RS
Holy crap
Old Feb 8, 2014 | 10:31 AM
Car: 91RS
Think I got it I need the chassis side of v8 motor mounts. They are bigger and wider and will make the fit to the needed holes https://www.thirdgen.org/forums/engi...swap-read.html. When placing the v6 chassis side against the v8 engine side on the motor it was way too small so the v8 he's got to be much bigger thx for the sticky
Old Feb 11, 2014 | 07:35 AM
Car: 91RS
and here https://www.thirdgen.org/forums/engi...ing-motor.html
92projectcamaro
Sep 29, 2015 07:07 PM
bbsr72
Sep 27, 2015 05:55 AM
89bird2.8
Sep 18, 2015 07:46 PM
Jetmeck
Sep 4, 2015 12:29 AM
