T5 to 700r4 shifter wiring help needed!
Old Feb 8, 2014 | 01:47 PM
UberFast's Avatar
Car: 92 camaro rs
Axle/Gears: 10b 3.73 posi
I'm done with everything in my swap except for wiring the shifter harness. Where the heck do I tie into the reverse light wires? I know they're light green and blue but I don't see where they're at. And what's the orange and black wire for on the shifter harness?
Old Feb 8, 2014 | 03:01 PM
UberFast's Avatar
Car: 92 camaro rs
Anyone? Can someone at least link me to a thread containing my answer if there is one?
Old Feb 8, 2014 | 06:34 PM
vetteoz's Avatar
Car: 82 Z28
Engine: 383 SP EFI/ 4150 TB
Transmission: T400
Axle/Gears: QP 9" 3.73
Re: T5 to 700r4 shifter wiring help needed!
Is the P/N indication for the ECM so it adjusts the revs when you put it in and out of gear.
Org wire gets connected to the ECM ,terminal D16 on the '730 ECM
See
http://www.chevythunder.com/fuel%20i...ecm#1227730%29
black wire to ground to ground
They get run to the corresponding wires on the shifter plug
Old Feb 8, 2014 | 07:48 PM
UberFast's Avatar
Car: 92 camaro rs
I read somewhere that the blue wire I need comes off the turn signal flasher mounted to the fuse box. Can I tie into that wire?
Old Feb 9, 2014 | 12:26 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Need to look at the backup light circuit diagram for you car
Old Feb 9, 2014 | 12:28 AM
UberFast's Avatar
Car: 92 camaro rs
Hey thanks I got it figured out. I'm all good now I think. That orange wire with black tracer needs to be hooked up to the ECM correct?
Old Feb 9, 2014 | 04:30 AM
vetteoz's Avatar
Car: 82 Z28
Transmission: T400
Old Feb 9, 2014 | 05:07 AM
Tuned Performance's Avatar
Community Influencer
Car: 1967 Camaro, 91 z28
Engine: Lb9
Transmission: M20
D16 on your 1227730 , when grounded in p or n the ecm adds to the target rpm
Old Feb 9, 2014 | 09:04 AM
UberFast's Avatar
Car: 92 camaro rs
Alright sweet thanks guys! Big help! I'm about to get this swap finished up!
1992 Trans Am
May 10, 2023 07:19 PM
camaro11j
Sep 19, 2018 08:49 AM
IROCZ1989
Jan 24, 2016 03:55 PM
86camaroman201
Fabrication
Aug 11, 2015 10:39 PM
GEmrsn
Interior Parts Wanted
Aug 8, 2015 03:15 PM
